milkshake on the...
Old Mar 15, 2004 | 11:26 PM
hwcoll95's Avatar
Car: 1989 Iroc rebuild
Engine: 355 carb'd
Transmission: 5spd
Axle/Gears: 3:08 pos for a while
milkshake on the...
top end of dipstick ,but only after a long run,don't notice when just normal around town driving,but after a 300 hundres mile interstate run,notice it only on the dipstick,near the top(handle end),bottom of valve cover plug,and pvc valve has no residue??any suggestions???coolant level does drop some periodically,??but did that long b4 the milky look on the dipstick started??any suggestions??
Old Mar 15, 2004 | 11:41 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
You already know the answer. Water in the oil.
Old Mar 15, 2004 | 11:48 PM
hwcoll95's Avatar
Engine: 355 carb'd
Transmission: 5spd
but the....
question is where's the source???it doesn't overheat and the pppplugs look good?appears more like condensation?
Old Mar 16, 2004 | 12:12 AM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
on a 300 mile interstate run, I would think that the oil would get hot enough to burn off any condensation. If its not burning coolant, then I dunno. If you had said you weren't driving it far enough to get the motor to operating temp, then I would say condensation could be the answer, but I don't see that w/ the engine at operating temp that long.
Old Mar 16, 2004 | 12:19 AM
hwcoll95's Avatar
Engine: 355 carb'd
Transmission: 5spd
it don't make
sense,this is second road trip that i've noticed this,
Old Mar 16, 2004 | 05:59 AM
Vader's Avatar
A functioning PCV system usually controls that moisture very well. Make sure your's is operating.
Old Mar 16, 2004 | 09:49 AM
Annihilator's Avatar
Car: Caprice
Engine: 5.0 305 LO3
Transmission: 2004-R
If it were just mere condensation, you would find a yellow film on the underside of your oil cap. This might be a very small head gasket leak. Also check your coolant for "rainbow swirells" meaning oil in your coolant. Any white smoke other than the normal steam? Also look for crappier idle and such. If all this exists, you will need a head gasket job. Its not that hard :P
Mexinugget
Mar 18, 2015 12:44 PM
91RS84TA
Oct 23, 2009 10:42 PM
slepac
May 10, 2005 01:05 PM
Shadey_MF
Mar 22, 2003 06:50 PM
85 Berl
Jan 19, 2002 08:42 PM
