air pump
Old Mar 16, 2004 | 09:00 PM
kamaroirock's Avatar
Car: 02 z28, 03 wrangler sport
Engine: ls1, 4.0L
Transmission: t56, 4speed auto
air pump
i have to put in a new air pump soon and i heard that those torx bolts are involved. can anyone tell me if what i herd is true and if so if anyone would know the size of the socket needed.
Old Mar 16, 2004 | 09:06 PM
flyitlikustolit's Avatar
Car: 1982 Trans Am
Engine: 383 chevy
Axle/Gears: 4th gen 10-bolt, posi, 3.42 ratio
no idea. you need a new smog pump? you can have the one out of my 82 t/a... i'm about to throw it in the trash. it's probably a 9/16's socket, though. i don't think torx bits were on very many things back then.
Old Mar 16, 2004 | 09:21 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
I cannot remember the size off hand but you need a torx bit. They are usualy siezed into that bracket and only come out with some gridning. You can try to grind a slot into the head so that you can use a screw driver or grind around the bracket and get it out. I find it easier to take out the whole acessory bracket and remove it with a pair of vice grips. It is much easier that way. This is for a serpentine set-up and may be different with a v-belt style.
Old Mar 17, 2004 | 10:48 PM
25THRSS's Avatar
T-45 torx bit. VERY easy if you have the right tools!
Old Mar 18, 2004 | 03:05 PM
Engine: ls1, 4.0L
thanx
Old Mar 18, 2004 | 03:07 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
If by tools you mean 8 different vice grips, a grinder, and about 4 bits.... I had to go midevil on mine.
Old Mar 18, 2004 | 08:56 PM
25THRSS's Avatar
lol, as long as you have a T-45 torx bit it should be cake. If not, then I guess you'll have to go midevil, lol.
Old Mar 18, 2004 | 10:15 PM
TekViper's Avatar
Car: 1990 Pontiac Firebird
Engine: 3.1L v6
Transmission: Automatic
what engines and years use torx bolts? mine are just standard bolts on a 90 3.1
dyeager535
Aug 28, 2015 08:10 AM
Dialed_In
Aug 20, 2015 01:45 PM
mcquigg
Aug 13, 2015 02:26 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
