Is there a way to disable my car while I'm getting it painted?
Old Mar 19, 2004 | 08:17 AM
Mike89GTA's Avatar
Is there any way to make my car slower etc before I take it to Maaco. I'm worried they're going to be doing burnouts in it etc. Should I just tell them I'm keeping track of the odometer and not to drive it more than into the bay?
Old Mar 19, 2004 | 08:33 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Unplug the EST wire.
Old Mar 19, 2004 | 01:16 PM
MdFormula350's Avatar
also make sure it has very little gas in it
Old Mar 19, 2004 | 01:28 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Put the cheapest, crapiest, steel rims on it you can find. That way they wont get paint on your nice tires and rims. After showing up, pull the tail lights, if its camaro pull the grill, and headlights.
Do you have custom burning equipment? Anyway to change the prom chip to really lower the power w/o causing damage to the engine?
Old Mar 19, 2004 | 01:31 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
listen to this man.
if you dont, they WILL get paint on the tires and rims... they SUCK at masking the lights and grill and well.... its one of thoes things that make it look like a cheapo macco job instead of a decient one.
Old Mar 19, 2004 | 02:06 PM
Mike89GTA's Avatar
Oh, they're just painting the hood.
Old Mar 19, 2004 | 02:10 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
in that case....
still remove the headlights, and all 4 turn signal lenses... and swap your tires...
overspray gets everywhere that you dont want it.
Old Mar 19, 2004 | 10:38 PM
MYBLUZ's Avatar
Car: 1991 Z28 1LE A.K.A The blue rocket
Engine: Blown 383
Transmission: Full manual 700R4
Disconnect the throttle cable at the throttle body, car will idle. They can idle it into the booth, and romp on it all they want,with no WOT.
Old Mar 19, 2004 | 11:06 PM
MAXJEFF's Avatar
Car: 92 RS, 95 1500, 91 SHO
Engine: 355 LT1
Axle/Gears: 410's
Pull the engine
Old Mar 19, 2004 | 11:54 PM
deadhead1882's Avatar
Car: 82 El Camino
Engine: built 355
Transmission: T-56 upgraded internal
Axle/Gears: 10 bolt 3.42
just pull the ignition fuse
Old Mar 20, 2004 | 01:48 PM
scottland's Avatar
Car: '82 Z28
Engine: 350HO
Transmission: M4
if its an automatic, exactly as said above, disconnect the throttle cable from the throttle body. that way they can't go faster than like 3 mph.
Old Mar 20, 2004 | 02:38 PM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
How about... have them paint match the hood with the rest of the paint, go home, take off your hood and bring just the hood back...
Old Mar 20, 2004 | 02:49 PM
NJITIROC's Avatar
Car: 1989 IROC-Z
ditto, i doubt they could drive your hood very fast
Old Mar 20, 2004 | 06:54 PM
d_johnsen's Avatar
Car: 1989 Firebird
Axle/Gears: ?
you'd be surprised im sure someone in this world would try it
Old Mar 20, 2004 | 08:48 PM
CaysE's Avatar
Originally posted by MAXJEFF
Pull the engine
Hahha, I like this one.
My suggestion is to go there with the car, and then pull the hood off while you're there. That's probably your best bet.
Old Mar 20, 2004 | 08:58 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
you can say that again. Had an eclipse that I took in to get serviced and one of the mechanics at the mitsu dealer left the door open while he was lowering the lift. Needless to say, after getting it back after getting a new free door the entire car had overspray all over it. Paint looked terrible after that.
Old Mar 20, 2004 | 09:02 PM
Vader's Avatar
Burn a PROM with a fuel cutoff at 10 MPH instead of the 118 or 254MPH parameter that came with your car's stock PROM. You can't generate much wheelspin at 10 MPH.
Old Mar 20, 2004 | 09:04 PM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
Just switch the 1 & 8 plugs on your distributor.
Old Mar 20, 2004 | 09:44 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Unplug the coil wire on the distributor.
Old Mar 21, 2004 | 05:18 PM
max93's Avatar
install a rev limiter, or find a shop you trust not to beat your car.
Old Mar 21, 2004 | 05:35 PM
sittincamaro's Avatar
Engine: IVTEC 2.4L aka SBC
Transmission: auto
do yourself a favor bring it to a good body shop. youll get a good paint job, and you wont have to worry about them toying with your car. shops dont stay open with a rep of beating on the cars they work on.
Old Mar 22, 2004 | 10:39 AM
MYBLUZ's Avatar
Engine: Blown 383
I took my Z in to get an alignment, brought it home and discovered the front spoiler was missing alot of paint, and was cracked. Took it back and they played dumb. They apologized and said this sort of thing never happens. Then he gives me a card for a local body shop and says "here is the number to the guys that does all our body and paint work". Hmmm, I thought this never happened I said, he smiled. Anyway this thread has been making me think of ways of getting alignments without going to the body shop next. Maybe I could take the hole front suspention/k member down and get it aligned, then reinstall it in the car? Any other suggestions? Even when I'm getting tires I pull it on the lift, I stand there and watch everything. Anymore you just cant trust stupid people to not screw up your pride and joy.
Old Mar 22, 2004 | 10:43 AM
Mike89GTA's Avatar
Just got back from dropping it off, the place looked like a dump. I hope my car will be ok
Old Mar 22, 2004 | 08:40 PM
Vader's Avatar
"Your car? What car? Did you leave a car here? You got a receipt or something? We don't have any cars here..."
Old Mar 22, 2004 | 11:34 PM
92blue's Avatar
Former Sponsor
Car: 1992 Camaro RS
Engine: Yet another 350 TPI
Transmission: Borg Warner 6 spd
Pull the rotor out of the distributor and take it home with you. This also makes for a rather cruel practical joke to play on your friends car. Most people wouldn't check that until they have spent a couple of hours tring to figure out what is wrong.
9192camaro
16
Feb 3, 2019 12:21 AM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
kah992
Aug 19, 2015 02:55 PM
ElPaleterro85
Aug 13, 2015 03:49 PM
Exxon Limited
Aug 9, 2015 08:13 PM
