Car stalls after cam swap
Old Feb 21, 2001 | 05:45 PM
Dan87IROC-Z's Avatar
I got my engine all put back together with my new LT4 Hot Cam, and the car stalls and just can't hold idle. The car does however need have leaks at plenum to runner seals and the TB to plenum seals, you can hear the air rushing through so its a very severe leak. When I get this fixed it should fix the problem, right?
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Borg Warner 7.75" 9 Bolt Rear End
Current Mods: LT4 Hot Cam, Comp Cams 1.52:1 Roller Rocker Arms, Edelbrock TES 1 5/8" Headers, Hooker 3" Aerochamber Cat-Back System, Performance Resource Chip, Accel Ignition Coil, Cap, Rotor, 8.8mm Wires, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET (w/o LT4 cam): 14.32 @ 97.7mph
(corrected for elevation)
7.5" 10 Bolt with 3.42s soon to come!
Old Feb 21, 2001 | 05:49 PM
ede's Avatar
ede
if you fixed the leaks you'd off to a hell of a good start on fixing your other problems
ICON Motorsports
1st & 3rd
Old Feb 22, 2001 | 03:11 PM
Thanks, anyone else?
Old Feb 22, 2001 | 03:19 PM
Da91Bird's Avatar
Definitely fix those vacuum leaks first. Cars don't like them. If there is still a problem after that, check to make sure that you installed your distributor correctly. You could be a tooth or two off.
Old Feb 23, 2001 | 01:28 AM
BTT
Old Feb 23, 2001 | 02:27 AM
IROCZZ3's Avatar
Car: 87 Buick GN
Engine: 3.8L (231 cid) V6
Transmission: 200-4R
Axle/Gears: 10 bolt G80/ 3.42
make sure you didn't put the runners on the wrong side!!
1989 IROC-Z, ZZ3 shortblock with some bolt-ons.
13.20 @ 108.69, 2.2 60'
Old Feb 23, 2001 | 10:37 AM
Ray87Z's Avatar
Car: 94 Z28
Engine: LT1 w/ headers, catback, CAI, tune
Axle/Gears: 3.23s
In regards to your other post what did you find was keeping it from starting in the first place?
Ray87Z
-Vortec headed 350.
86 IROC w/ a cammed 305 TPI.
Formerly Ray86IROC.
www.inter-scape.com/Ray
Old Feb 23, 2001 | 05:39 PM
The original problem was that the distributor was 180* off. But you guys think those gaskets will fix it?
L98 TPI 350 (5.7L)
Old Feb 23, 2001 | 08:27 PM
new87's Avatar
Car: 87Z
Engine: ?
Transmission: A4
It help me to get mine on the road Wensday. I didnt have alll the bolts torqued right. After that I'm on the road with a much happier car. Also make sure you have all of your vacuim hoses back where they go.
87 Z28 305 TPI, Auto, LT-1 cam (peanut is history), roller timing set, 2.73, Gutted air boxes, K & N fillters, Dyno Max 3" cat back, 8.8 mm spirals, rapid fires, and 170* Stat.
Old Best 15.414 @ 87.47.
Old Feb 23, 2001 | 11:52 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Dan, not trying to be a smart aleck here, but that's kinda like asking "If I patch that hole in my tire, you think it will keep it from going flat?"
Old Feb 24, 2001 | 01:32 AM
LOL, you're funny Mike, but thanks, I guess the engine can barely get any air and thus it runs poorly, I mean, VERY poorly!!
L98 TPI 350 (5.7L)
Old Feb 24, 2001 | 03:03 AM
JakeJr's Avatar
Car: 1996 Vette / 1992 GSX1100F Suzuki
Engine: 1996 Corvette Coupe 388 LT1 (+.060)
Axle/Gears: 3.07
Actually, Dan, it's just the opposite. A vacuum leak introduces air into the engine that has not been measured by the MAF and so the proper amount of fuel hasn't been added.
You'd really be surprised at how a very tiny leak will play havoc with the idle of a TPI engine.
I had a very small one not long go that took me a week to track down (injector "O" ring) and before I found the cause, my engine wouldn't idle at all witout me taking the IAC out of the picture.
I had to crank up the "park" idle speed to 1000/1100, just to keep the engine running in gear at 800. Stalled at stop lights and was not only a royal PIA, but embarrassing too.
Before you start throwing parts at the problem, make sure it's sealed tightly.
Jake
1986 Corvette Coupe, 415 CID, Edelbrock 6073s, ZZ9
[This message has been edited by JakeJr (edited February 24, 2001).]
Old Feb 24, 2001 | 07:02 AM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Well, Kevin91Z discovered he also needs an eprom. You'll probably find the same thing.
Old Feb 24, 2001 | 10:23 AM
branz28's Avatar
Car: 1989 IROC-Z
Engine: 383
Transmission: Pro-Built 700R4 2400 ACT Stall
Axle/Gears: 2.77 Borg Warner 9-Bolt
Heh, Glenn thought the same thing i did. I wouldn't doubt that you may be able to get it to idle after the leaks get fixed but your probably looking at a new prom. Gotta admit, your mods are getting up there and only so much can be changed before something starts screwin up
89 IROC-Z 350 TPI
-Flowmaster Catback
-Performance Resource Chip
-700R4 (Rebuilt) Too much done to actually list
-K&N Airfilters
-Ported Plenum
-2.77 Gears (not much to brag about but eh, its there)
-MSD 8.5 mm plug wires
-Problems every other day with the car (probably not a mod, but to me it sure makes a difference)
1984HO
Mar 19, 2021 11:59 AM
midge54
Dec 27, 2019 04:14 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
Wade787b
Sep 29, 2015 01:15 PM
TreDeClaw
Aug 14, 2015 06:58 PM
