pulling gas tank from 89 gta
Old Mar 27, 2004 | 04:44 PM
blkgta's Avatar
i am pulling my gas tank from 89 gta to change the fuel pump
& upgrade . do i have to drop the rearend ?
or will the tank come out ?
any suggestions , i have never done this before .
Old Mar 27, 2004 | 04:55 PM
TA5LiterHO's Avatar
Car: 1984 Trans Am WS6
Transmission: 700r4 Highly Modified
You do not have to drop the rear end if you cut the exhaust and pull the muffler out. The only problem I had was getting the tank to sit back up there all the way so the straps would reach. The filler neck hangs up some also. I would suggest going the muffler route if you don't want the project to become overly involved. It would be easier fishing the filler neck out with the rear end lowered though.
Old Mar 27, 2004 | 07:39 PM
blkgta's Avatar
thanks for the advice - i did take the muffler
off already. hope to have it out tomorrow.
thanks
Old Mar 28, 2004 | 12:51 AM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
Just unbolt the shocks and slowly drop the rear down. Make sure no brake lines get stretched though... I've pulled my gas tank out many times and I'd seriously rather pull my motor than my tank because its that much of a PITA.
Its kinda (by kinda I mean really) tricky getting it out. You need to push/pull/twist it just the right way or it'll never come out or go back in. Also make sure when you remove the straps you dont bend them up ...if you do you'll have a fun time trying to get them back on.
Old Mar 28, 2004 | 06:05 AM
ede's Avatar
ede
dropping the tank isn't that big a deal to me. it halps a lot to have a helper reach in the fuel door and guid it back in place when you put it back in
Old Mar 28, 2004 | 08:14 PM
blkgta's Avatar
took the advice , took about 1-1/2 to 2 hours with a buddy
hardest part was getting the neck out
modified the upper lip inside the gas door by rolling
the lip . thanks
Old Mar 28, 2004 | 08:42 PM
dj haf's Avatar
Car: 1990 IROC-Z
Engine: 350 L98
did you drop the rear or remove the exhaust?
Old Mar 28, 2004 | 08:47 PM
blkgta's Avatar
removed the exhaust , it worked out good
cause i will be putting on a new muffler anyway
jack the car up as high as possible , & put it on jackstands
Infested
May 22, 2018 11:56 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Andrew6.688
Dec 13, 2015 10:59 AM
mustangman65_79
Sep 1, 2015 03:51 PM
AkDrifted
Aug 17, 2015 07:45 PM
