Which wire do test for voltage on tps?
Old Mar 1, 2001 | 01:46 PM
HIX5000's Avatar
When adjusting tps voltage which wire do I check the voltage on?
1988 Camaro RS
2.8L five speed
Money pit from hell!!
1988 Camaro
2.8L automatic
t-tops
160* THERMO
Rapid fire plugs
Old Mar 1, 2001 | 06:35 PM
87kevroc's Avatar
Car: 1987 Chevrolet Camaro Z28 IROC-Z
Transmission: TeamTripp Performance
Check out this link
http://www.sc3gfb.org/resources/tps.html
Old Mar 1, 2001 | 06:36 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
If you want some pics, click here: TPS
If you live in Southeastern US, check us out!
South East Thirdgen
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
Old Mar 2, 2001 | 09:58 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I was going to mention the tech article here (at https://www.thirdgen.org/newdesign/tech/tpimod2.shtml ) , but I noticed it doesn't say which wires to connect the voltmeter to. The original article in Hot Rod had a picture next to it that showed the detail...
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Mar 2, 2001 | 02:14 PM
JakeJr's Avatar
Car: 1996 Vette / 1992 GSX1100F Suzuki
Engine: 1996 Corvette Coupe 388 LT1 (+.060)
Axle/Gears: 3.07
Looking at the TPS installed on the TB you use the top and middle wire.
The lower wire is a reference voltage wire and isn't used for setting the TPS voltage.
It doesn't matter which wires your voltmeter leads connect to; either positive to the top wire or negative to the top wire. If you connect it one way you get a positive reading on your voltmeter and if you connect it the other way your digital voltmeter will just show a - (negative) sign before the reading.
The top wire is the one you'd connect the negative voltmeter wire to and the center wire gets the positive.
The lower wire can be used to check the reference voltage, which should be 5 volts.
Jake
1986 Corvette Coupe, 415 CID, Edelbrock 6073s, ZZ9
[This message has been edited by JakeJr (edited March 02, 2001).]
Old Mar 2, 2001 | 03:06 PM
JakeJr's Avatar
Axle/Gears: 3.07
<font face="Verdana, Arial" size="2">Originally posted by 87kevroc:
Check out this link
</font>
I've got a question about the info on that link about resetting the IAC that says to start the engine with the jumper wire (A&B on the ALDL) still connected.
The references I've seen say to remove this jumper wire/paper clip before starting the engine.
It's my understanding that inserting the jumper wire into the A&B terminals of the ALDL causes the IAC pintle to fully extend (close of the air passage), thus establishing a new reference point for the ECM to set IAC counts.
So once the IAC pintle has been fully extended (that's why the 30 seconds), the jumper has done it's job, so the IAC connector is then unplugged and min idle is set.
Has anyone else come across any other source saying to leave the jumper in place on the ALDL when starting the engine?
I'm concerned that this my damage the ECM.
Jake
JakeJr's Avatar
Axle/Gears: 3.07
Dupe, sorry
Jake
Old Mar 2, 2001 | 05:36 PM
HIX5000's Avatar
Thanks for the links. The ALDL is the connector pluged into the IAC correct?
Old Mar 2, 2001 | 06:09 PM
RednGold86Z's Avatar
Car: 92 Form, 91 Z28, 89 GTA, 86 Z28
Engine: BP383 vortech, BP383, 5.7 TPI, LG4
Transmission: 4L60e, 700R4, 700R4..
Axle/Gears: 3.27, 2.73
The ALDL is in the driver compartment. Right about where your right knee would be. It has a bunch of pins in the connectors, the tech article can help you better. It's the one that tells you how to check your own codes.
Old Mar 2, 2001 | 06:15 PM
HIX5000's Avatar
the illistration has the pins numbered. Is A and B pins 1 and 2
eightsixseven
Dec 16, 2024 01:50 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
