Best way to port & polish: Carbide or Standard Abrasives
Old Apr 5, 2004 | 09:25 PM
irocfreak's Avatar
Car: 1986 Iroc-z
Engine: Soon to be 350
Transmission: 700junk4
I'm getting ready to port and polish my cylinder heads and i want to know which method you guys prefer? There is standard abrasives kit for porting and polishing heads and there is also the carbide burring kits. Which way should i go and what are the advantages and disadvantages? Any input is appreciated.
Thanks,
Dane
Old Apr 5, 2004 | 09:48 PM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
Carbide cutters all the way.
The SA stuff is cheap and won't last long enough to do both heads.
The carbide cutters are less expensive and will definitely last long enough for a couple of pairs of heads.
Old Apr 5, 2004 | 09:53 PM
irocfreak's Avatar
Car: 1986 Iroc-z
that was the way i was leaning. thanks
p.s. - ive read your thread on porting and polishing heads. you've really helped me out alot:hail:
Old Apr 5, 2004 | 10:27 PM
82CamaroZ28's Avatar
Car: 1982 Camaro Z28
Engine: Self-built 350
Transmission: Pro-Built 700r4 w/2800 Vigilante
Axle/Gears: Eaton 3.73 w/Moser axles
Yeah, definately carbide...that's all I used when I did a set of '416's this past winter.
In this thread there are some good pics of how things should optimally turn out and also which carbide bits work best:
https://www.thirdgen.org/techbb2/sho...hreadid=211826
Old Apr 5, 2004 | 11:15 PM
irocfreak's Avatar
Car: 1986 Iroc-z
how long can i expect to take doing my l98 heads. I want to take my time and make sure i stay consistant.
Old Apr 6, 2004 | 01:44 AM
Engine: 305-4v
To do a thorough job you are looking at 30 hours. That's for a first time p and p job.
Take your time, you won't regret it
Old Apr 6, 2004 | 01:48 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
At the risk of being contrary, I'd say "Both".
But there I go again.
Old Apr 6, 2004 | 01:56 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
I agree, both.....
The SA stuff is quite expensive to use for an entire port job, because you'll go through so much of it. But, if you use a carbide cutter for the heavy-duty metal removal and use the SA products for finishing, you get the best of both worlds.
Old Apr 6, 2004 | 06:59 PM
OMINOUS_87's Avatar
Both.
Carbides for the big dirty business, SA kit for the rest.
gixxer92
May 18, 2017 11:20 AM
Gunner242
Dec 25, 2015 04:49 PM
Reid Fleming
Oct 10, 2015 09:56 PM
bplessy
Sep 30, 2015 12:14 PM
Bigold4x4
Sep 28, 2015 05:21 PM
