pics of the egr solenoid/vacuumstuff please
Old Apr 10, 2004 | 04:57 AM
irocnroll89's Avatar
From: previously OKINAWA JAPAN,georgia, now new england
Car: 1989 IROC--1989 T/A
Engine: 5.7 TPI in both
Transmission: W/C T-5 in both
Axle/Gears: B/W 3.27 in both
I really need some good pics of how the vacuum hoses go into egr solenoid. I pulled it all out a long time ago, and the hood doesn't have the diagram sticker. It looks like a 5/16" hose goes into the egr solenoid, and there alot of T-fittings. Anything from the plenum, out would be great. Thanks guys. shawn
Old Apr 10, 2004 | 09:59 AM
Vader's Avatar
URockNRoll,
The supply to the EGR solenoid is from the timed vacuum port on the underside of the throttle body. That supply line has a "T" which also feeds the EVAP canister solenoid. The other port on the EGR solenoid connects to the EGR valve pilot itself, and the port on the opposite end of the EGR solenoid (the one all by itself) is the atmospheric vent, that once had a foam "filter" cube stuck to it.
Should I mail you some self-adhesive decals for the underside of your hood? I'd need some PM with more specifics.
Old Apr 12, 2004 | 11:26 AM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
Vader --- (or someone else in the know...)
I'm trying to confirm I hooked up my EGR solenoid correctly when I did my 383 swap. The vac sol has 2 ports - which one goes to the EGR valve? Is the metal one for the valve and the non-metal port for the vacuum feed?
Just trying to make sure I did it correctly.....
Have a Great Day, and Thanks for your time!!!!
- Vern
Old Apr 13, 2004 | 12:29 PM
Cole's Avatar
ttt
I would like to know which port goes to the valve as well. Thanks.
Old May 13, 2004 | 12:06 PM
AlexJH's Avatar
Engine: 5.7L V8
ttt
Does anyone know the answer to this? The previous owner didn't have EGR hooked up (dunno how he passed emissions) and I don't have the original connector.
Old May 13, 2004 | 12:19 PM
vernw's Avatar
Yeah, I'm still waiting for that answer as well.....
Old Jul 11, 2004 | 08:57 AM
JA_Formula_89's Avatar
Car: 89 Formula
Engine: 5.0 TPI (F-Code)
Transmission: 5 Speed Manual
Did anyone ever figure this out? I need to know too!
Old Oct 20, 2005 | 01:28 PM
Nitsuj86Iroc's Avatar
Car: 86 Camaro Iroc-Z
Engine: 305ci TPI
well, from what iv read from people who have posted which goes where the gray metal one goes to the throttle body as a vacuum feed, and the black plastic goes to the EGR itself.
i have not seen this for myself yet, but a little searching and thats what seems to be the right answer. im about to go check my egr system now.
Old Oct 20, 2005 | 01:43 PM
vernw's Avatar
Please report back so we can all know for sure.....
Old Oct 20, 2005 | 05:46 PM
Engine: 305ci TPI
Yes, look at Vader's picture, youll see the black hose and the grey hose. The black goes right to the EGR itself, the grey hose runs upfront under the plenum and to the throttle body, attaching to the throttle body with a "T" joint thing.
if your having problems witht he egr not working, the problem might be that the grey hose cracked, mine did. iv been failing NOx emissions and this is probably why.
does someone know the best way to repair a cracked vacuum hose? i was simply going to wrap electrical tape temperarily, possibly try super glue as long as none gets inside to clog it.
Old Oct 21, 2005 | 07:34 AM
yes vader's pic helped out. As for the vaccum line, i would cut off the plastic at the crack, and put a piece of rubber "3/16" line in between. This is what i did when my throttle body plastic line crapped out. As a bonus you cana dd a little length to it, to allow you to pull the throttle body off, and unhook th line after it is unbolted.
regards
Old Oct 21, 2005 | 09:12 AM
vernw's Avatar
THANKS!!!!
FWIW - Autozone and O'Reilly's both carry the small hard plastic vacuum lines. Pep Boyz probably does too.....
gta892000
Aug 11, 2019 11:16 AM
92firebirdguy
Sep 1, 2016 07:53 AM
3rdgenkindagal
Sep 13, 2015 02:02 PM
Kenwood
Sep 11, 2015 12:50 PM
rjcme
Sep 5, 2015 01:23 PM
