New Fuel Pump...Fuel Cuting Out at HIgh RPM
Old Oct 20, 2005 | 02:24 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
basically i just put a brand new walbro high pressure fuel pump in my 1991 z. after i put the pump in the car has a hard time starting unless i give it gas (like its not getting any fuel, it will just keep turning over). now after i went to the track i realized my car is cutting out (most notably at approx 80mph, 4500rpm, 3rd gear). it hesitates extremly badly but only when pushing the car hard.
anyone have any suggestions on whats wrong here?
TIA!
Old Oct 20, 2005 | 02:47 PM
Sounds like a fuel delivery problem.
What's the FP WHILE IT'S DOING IT? (not while it's sitting idling...)
Old Oct 20, 2005 | 03:32 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
im 99% sure it has to do with the new pump but i just dont undertand what could be causing it. and i dont have a fuel pressure gauge to test that unfortunatly...
Old Oct 20, 2005 | 03:37 PM
Sounds like, it's time for a trip to AutoZone for a gauge.... one of the most fundamental pieces of test equipment for working on fuel injection. You'll get your money's worth out of it, sooner or later; maybe right now.
Old Oct 20, 2005 | 06:53 PM
ws6transam's Avatar
Car: 1984 Trans Am WS6
Engine: Minirammed 385, 396 RWHP
Axle/Gears: 3.73 Moser 12-bolt
It sounds more like a ground problem to the pump. You probably have a high resistance ground wire and it's starving the pump for voltage.
I had to silver-solder my ground wires throughout the sending unit because GM used a spot-weld as a ground path. Perhaps yours is the same way?
A little work hardening and the resistance will go sky-high. It only takes an ohm or two to K.O. your pump, which has only one or two ohms in its own windings. Add one ohm of resistance to your ground path and you lose 33% of your current.
--drb
Old Oct 20, 2005 | 11:27 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
i thought it might have to do with the wiring, putting more demands on the old wire might actually cause a problem that wouldnt show up with the factory pump's demands.
but i still didnt get the part about it not starting like it should, i can understand at WOT but not when starting
Old Oct 21, 2005 | 09:06 AM
ws6transam's Avatar
Like the others said, perhaps it is time to invest in a fuel pressure guage. When you first key on the ignition, the pump is supposed to engage for a second or two in order to pressurize the fuel rail. Fuel pressure is supposed to be in the neighborhood of 45 PSI.
Have you adjusted the fuel rail pressure at all? If so, then maybe you have exceeded 60 PSI and you are hydraulically locking up the fuel injectors. That's a bad, bad thing and will make the engine lean out under power.
Try this first: Get yourself a pressure gage and a multimeter.
1) Check fuel pressure at key-up and at idle. It should be around 45 PSI in both cases with the pressure regulator disconnected from manifold vacuum.
2) Get under the car and check pump voltage at the connector. It should be at least 12.5 volts at all times
3) Check the pump resistance by unplugging the connector at the fuel tank and probing the pump: With the pump and the series resistance of the wiring harness, the series resistance should be no more than two ohms. 12.5 V / 7 AMP = 1.75 OHMS
If you key up the car and pressure spikes, then drops rapidly, it means one of two things: Either you have a leaking injector or else you have a bad check valve inside the fuel pump.
Hope this helps,
--Dan
Old Oct 21, 2005 | 09:35 AM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
very good info. now that i think about it the metal end cap on the pump nipple (the check valve) fell off wheni was installing the pump. i put it back on and it was secured inside the rubber fuel hose but that could possibly be my problem.......damn
specialized
Jun 18, 2022 09:26 AM
jklein337
Sep 19, 2018 06:23 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Armored91Camaro
Aug 12, 2015 09:41 AM
