its finally time to decide tbi, tpi, or carb.
Ok i'm finally pulling my motor (lo3) out of my car. I got a complete engine out of an 85 iroc 305tpi everything except computer got harness and what not though. My little delima is what type of fuel delievery should i go to. This 305 is gonna be heavily modded. Should i stick with tbi and upgrade to the holly670 about 300 bucks dont need to change really anything but the computer chip. Go to tpi need to get fuel pump, bigger fuel lines and computer, about 400 dollars i guess. Or go to carb which i will need to spend a lot of money anyways but with carb wont it damage my 700r-4. I would really like to hear everyones opinons.
91 RS' TBI 305
mods:
dynomax exhaust, lakewood control arms, gutted cat, pioneer deck, tbi spacer, jet stage 2 chip, K&N four inch element and open element, accel cap and rotor, moroso plug wires, msd blaster coil, bosche +4 spark plugs. Alot more mods to come!!
visit my page http://www.geocities.com/motorcity/pit/8410
91 RS' TBI 305
mods:
Car: '92 RS
Engine: In pieces
Transmission: Built 4L60
With a 305 you are not going to damage your 700R4. I understand that you are heavily modding it. That's fine but there is a very little chance you will see more than 350 hp out of a NA 305. I suppose you could see more on the bottle But you would need a 200 shot to hurt the R4. IT's good up to about 400 ft/lbs of torque. So go with the fuel delivery system if your choice.
Also **t a shift kit in your trans. or have it rebuilt with some performance parts. You'll thanks me later.
Later,
lars
'92 RS 305 TBI
K&N Open Element
Ultimate TBI mod's (thanks Pablo)
Cam[.442"/.465" x 218*/224* @ .050", 10:1 Hypereutectic Pistons
Performer Manifold
Shift Kit, Corvette servo,
and 2800 Stall Trans Specialties Converter,
Gutted Cat, IAT Resistor
MSD Blaster Coil, Accel Cap and Rotor
[This message has been edited by lars92RS (edited July 27, 2000).]
Later,
lars
'92 RS 305 TBI
K&N Open Element
Performer Manifold
oh no no u misunderstood me. My transmission is beefed up big time i have a 2500 stall convertor in it and a shift kit with a manual valve body. Um i meant switching to carb wouldnt that make the convertor not lock up. I thought it would fry my brand new tranny if i get rid of the computer.
91 RS' TBI 305
mods:
91 RS' TBI 305
mods:
Car: 4
Engine: 6
Transmission: 5
You can wire up a switch to lock it up manually, if that's all you're worried about.
I would absolutely not go back with the TBI. Beyond that, the choice between the TPI and carb will boil down to the usual cost vs. performance vs. legal question. The carb wins the performance vs. cost one hands down, except that you already have the TPI. You'll have to buy an ECM and a fuel pump, so you'll have to be the judge of the costs.
Car: YTG Camaro
Engine: 383
Transmission: TH-350
I too have considered the same things. I put a 327 in and kept the 700r-4, and my original intake was allready carb'd. By the end of the summer I had to put a new trany in it. I went w/ the 350 basically because of availabilty and reliability. I dont know what type of HP & Torque curve the new motor has yet but I am pretty sure it was a major culprit. Have you looked into the Holley EFI systems I am almost convined to go this route. TPI is so much more of a pain. Carb and nice and simple but I would like better fuel milage and throtle responce. The edelbrock 650cfm I have not is not the best, I think there is room for improvement.
'84 Camaro 327ci Bored .030 over w/ 5.7" stroke. 3.73 geared Auburn Limited Slip Diff. FlowMaster Muffler w/ Shortie Headers. TH-350 Built Trany Underneath B&M Mega-Shifter. Many Engine compartment Dress Up Mods. Edelbrock High Flow Water Pump w/ Flex-a-Lite Cooling Fan.
So, like, sell the Edelbrock (read Carter)
and buy a Holley 650 double pumper or 750 vacuum secondary.
BOR
Transmission: 4L80E/4L80E
Another consideration: The TPI bolts up to the engine you are modifying, while the TBI would not (speaking of the center two bolts on each side of the manifold). Depending upon your modifications, such as aftermarket heads or carb intake, your choice could correct that issue. Either manifold could be modified to fit either type of head as well.
I've got an LG4 now, just picked up an '87 LB9 dirt cheap, basically with what you got but with ECM and w/o injectors/rails/regulator. I'm going to do the swap, building the engine up over the winter with World 305 heads and cam upgrade. Why? For each 220-240 miles per tank of gas, I spend about 5 miles at the track. I'll do the TPI porting talked about on these boards, AFPR, headers, cat-back, etc. The improved mileage and the fact that I got a great deal make it worth it to me.
Carbs are fine (I'm getting 19-21 mpg even with my trips to the track); I'd like to move ahead.
82 Berlinetta, orig V-6 car. Rescued w/86 LG4/TH700R with all harnesses, sensors, ECM, etc. 3.08 open, cat-back from '90 305HO, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress.
57 Bel Air, my 1st car. Currently 396 .030 over, Weiand Action+, Edelbrock 1901 Q-Jet, Jacobs Omnipack, 1-3/4" headers, TH400 w/TCI Sat Night Special conv & shift kit, 3.08 10-bolt, AMSOIL syn lubes bumper-to-bumper. Best 15.1 @ 5800' Bandimere. Daily driver while Camaro was being put together.
Car: 91 Red Sled
Not sure if it was said in this post already but about the carb trans killing. You're right about the torque converter not locking up but there is a kit sold by jegs that'll lock it up for you when it's in 4th gear. Another idea is to install a trans cooler, it's extra insurance and a lot easier to spend $40 now than $1400 in a few months. I'd go with TPI if you're keeping the 305 since the TPI system was designed to work very well with the 305. Then again it's an expensive swap with the fuel pump and computer/wiring. It's all up to you. If daily driver then TPI is in, if not then TPI is sold and that money would go to the TBI or carb build up. Car Craft liked the quadra-jet up to 280hp from the LG4 305 and when they swapped to holley it made not even 1 hp difference. If you're going to do more than 300hp with the 305 then I think a carb or TBI is the best way. Carb would require the torque converter lock up but TBI would need a custom chip and larger injectors. It's a toss up really. Depends totally on what YOU want to do, just don't expect the stock 305 TPI system to make lots of power for cheap.
, Jon (91 RS too many mods to list)
wow i havnt posted on this site in months i guess the winter months have stoped me. Well a lot has changed. I got a 350 for my rs. Its not put in yet. Its going to be carb with roughly 400hp. ALso i got a 2001 ss camaro. Well thanks for the advice. Check out my page to see my new car.
91 RS' TBI 305
mods:
dynomax exhaust, lakewood control arms, gutted cat, pioneer deck, tbi spacer, jet stage 2 chip, K&N four inch element and open element, accel cap and rotor, moroso plug wires, msd blaster coil, bosche +4 spark plugs. Alot more mods to come!!(update 11/01/00 pulled engine
2001 camaro SS LS1 onyx black, SLP dual/dual center exhaust which brings horsepower to 335hp and 350ftlbs of torque, T-tops, 6 speed, Hurst shifter, cags!, power everything
mods: mti lid, k&n, took screen out of air flow sensor.
[This message has been edited by z28wiz (edited March 08, 2001).]
91 RS' TBI 305
mods:
theshackle
Sep 17, 2020 08:26 AM
[For Sale] 1 3/4 budget LS swap headers NEW (CA)
topteam54
LSX and LTX Parts
Aug 11, 2015 07:15 PM
