remote solenoid question
Old Apr 16, 2004 | 11:29 PM
2 dope's Avatar
Car: 1985 Camaro Z 28
Engine: 305 LG4
Im a bit lost, i have the diagram on the instructions and i think i understand them. My question is, coming out of the firewall on my car are 3 pink or red wires, 2 of the wires lead into 1 which brings it to 2 wires. What wire is what?
Im installing a remote solenoid and it only lists 2 wires coming out of the firewall
the remote solenoid is a ford type solenoid. Do i have to run a wire from the remote solenoid to my ignition coil? Where is the wire that is on my coil, its a in cap coil. My car is HEI.
please take a look here: this is what im trying to do
http://www.novaresource.org/starter.htm
Old Apr 16, 2004 | 11:45 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
The red wire splits into two wires because it goes to two connections on the ignition switch, "START" & "ACCESSORY".
Old Apr 17, 2004 | 12:02 AM
2 dope's Avatar
Engine: 305 LG4
ya but the 2 wires split into one, not 1 into 2
where would i hook the wire up to my ignition cap?
where is the ignition switch? I though i just had to hook the wires up coming through the firewall to the remote solenoid
Old Apr 17, 2004 | 09:58 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Well, the ignition switch is on the steering column under the dash. Just curious here, what kind of car are you putting that in. Looking at that web site, those diagrams are for a 62 - 79 nova and a ford. If you are putting it in a 85 camaro, the wiring is different from what your schematic shows.
Old Apr 17, 2004 | 01:46 PM
2 dope's Avatar
Engine: 305 LG4
I know where the switch is lol, i meant is there a wire connected to it that runs out the firewall which there is 2 others that hooked up tp the original solenoid.
Also the diagram on the guys site is basically the exact same diagram the summit solenoid came with. Its going in my 85 z28
Does anyone have a diagram that shows how to hook it up on a camaro?
Old Apr 17, 2004 | 01:49 PM
2 dope's Avatar
Engine: 305 LG4
has anyone else ever installed a remote solenoid in their 3d gen?
Old Apr 17, 2004 | 01:53 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Not being sarcastic here, but shouldn't the summit diagram show that if it is designed to be used in a 85 camaro?
Old Apr 17, 2004 | 02:17 PM
2 dope's Avatar
Engine: 305 LG4
the solenoid can be used on 3rd gens, even for non HEI 3rd gens, i mean it cant be impossible to install right?
Old Apr 17, 2004 | 04:40 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
According to your first post, your car has the HEI ignition on it. According to the diagram I have seen on that website for it. That remote solenoid system will only work on a car with a NON-HEI igniton system.
Old Apr 17, 2004 | 05:21 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
Ignore the 'I' terminal on the remote solenoid.
Extend your two or three heavy red wires to the solenoid and attach them to the same large stud as the cable coming directly from your battery. From the opposite large stud, run a heavy cable (number 1 gauge or so) to the large stud on the solenoid on the starter itself, and a short jumper wire to the 'S' terminal on the starter's solenoid.
Last, extend the puple wire that originally went to the starter solenoid, and attach it to the 'S' terminal of the new remote solenoid.
You can kind of see the setup I have in my Formula next to the puke tank, and it obviously has HEI. http://www.hioutput.com/pete/Formula/engine1.jpg
Enjoy.
Frozer!!!
Jan 19, 2024 04:55 PM
jklein337
Sep 19, 2018 06:23 PM
fasteddi
Sep 2, 2015 10:29 AM
injdinjn
Aug 28, 2015 12:51 PM
redmaroz
Aug 16, 2015 11:40 PM
