Tapping Lifter Galley Holes for Roller Cam Spider??
Car: 5.3L turbo 2800lbs RWD
Transmission: 4l80e
Axle/Gears: 3.512
Im pretty sure everyone knows that older blocks have no lifter retainer plate boss in the lifter valley.
What i was thinking is simple, you know how sometimes they install "stand pipes" in the lifter valley to keep oil from draining down onto the cam? well that involves tapping the oil drainback holes.
I was thinking of tapping them, but then using studs that bolt down the Spider Retainer plate in the correct position, so that a roller cam may be used in a non roller block. I assume I would need to use the 3.6 "long lifters" though, am i correct on that one?
Car: 88 Camaro
Engine: L98 350
Problem is you're drilling into the center oil gallery and it's pretty thin cast there. Don't want to block off that oil flow - and the area of the block where the lifters are is also machined different for them. Be nice to figure out a way to use the factory parts though, save big money.
Transmission: 4l80e
Axle/Gears: 3.512
Originally posted by ede
be a great way to make an internal oil leak. why not use the original roller cam set up, the one befoer gm decided to reinvent the wheel.
See the blue things? Those are installed to the drain back holes, Now imagine if I could Mount the Spider Retainer plate to THAT instead of the stock location. I think it would work! Im going outside to mock it up to my 350 as we speak.
Transmission: 4l80e
Axle/Gears: 3.512
ok lets say you have the spider mounting worked out with no drilling into the lifter gallies. how you going to mount the retiner plate?
You mean the dog bones? I thought the lifters retained them left to right, and the spider retained them from moving up off the lifters?
Isnt that all there is? And isnt the difference from the 3.1 to the 5.7 Roller lifters length, the 3.1 being longer to clear the top of the lifter bore so the dog-bone will work?
edit: Just went outside and double checked on my roller L03 305 block. All I pulled out was a spider plate, 8 dog bones, and 16 lifters. Am I missing something here?
Transmission: 4l80e
Axle/Gears: 3.512
the cam retaining plate on the front of the block. i think anyway it's done isn't right and is a halfassed way around doing it right and spending the money to do it right.
In a way i think its the same or better than the factory's mounting spot. I mean so you bolt the plate down to raised boss's, or you bolt it down to some studs sticking out of the lifter valley. whats the difference? I think the studs would hold it better. i mean, its not like the plate wears or moves or anything. it just has to stay put, and thats not hard to do...
Engine: Many
Transmission: Quite a few
so you'd basically have a standard 'old' style roller set-up, minus the expensive retrofit roller lifters. If you used those breather stands, or the drilled holes and made some custom studs to go in there, split the factory spider down the middle, and made a z-shaped bracket to mount the half-spiders to the studs, I think it would work, if two things:
1. you could get the 3.1L lifters cheap enough
2. the factory 'figure 8's' sat squarely above the lifter bores, so there would be no chance of binding.
so you'd have a bit of extra hardware in the valley--- lock-tight and lockwashers should do fine there; for the more paranoid, use locknuts also.....
the cam button and torrington bearing has worked for all these years, shouldn't be a problem.
I'd say, try it out.....worse case is you are out a busted motor....they make more......
of course, you could buy 'cheaper' mechanical roller lifters and use a solid roller......
Car: '85 IROC
Engine: LB9
Transmission: 700 R4
I'm in the middle of one of these retrofits.
I think it doesn't matter how the spider is held down as long as you don't mess up the oil passage by drilling a hole through it. Be careful in other words.
Those bolts that hold down the spider have to be the least stressed bolts on the entire motor. For me the tricky part is grinding down the tops of the lifter bosses to make a good fit for the doggone dogbones.
Some guys don't like the idea of this retrofit... IMO, What it really comes down to is how much is your time worth ?? If you' re getting paid a good wage at work, then it ain't worth it to burn up your time trying to grind and drill your block to make 3.1L lifters fit in it, it's better to just get a fresh roller block. But if you have some idle time on your hands, and you do it right, I can't see any reason it shouldn't work.
It's the "cheap" way to do a hydraulic roller retrofit
Former Sponsor
Car: 1992 Camaro RS
Engine: Yet another 350 TPI
Transmission: Borg Warner 6 spd
It would probably be less work to attach the spider to the heatshield underneath the manifold with spacers.
Car: '89 GTA
Engine: a bunch of pieces
Transmission: still there - very stockish TH700
Of course there's still some tweaking needed with spring locators, but if someone's hard diy'er... Senior Member
Engine: 305TBI
Axle/Gears: B&W 9 Bolt 3.73
just drive your current nonroller engine until it blows up then buy a roller block and be done with it. the money your spending now you could save for a roller block, i doubt if youll be able to get a set of roller lifters real cheap. see the other way around it is to buy a block with that already done and proven working parts. using breather extensions in place of the proper parts doesnt seem like a good idea.
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Originally posted by z_power
...and we're getting closer to another solution: use revkit with double springs - inner ones for lifters and outer ones for foctory "oculars"
Of course there's still some tweaking needed with spring locators, but if someone's hard diy'er... Member
Car: '89 GTA
Originally posted by Stekman
OH ok. Those are some long *** springs then.
edit: less parts in the lifter valley = less parts laying in the oilpan when something's wrong; go with the retrofit-lifters, they're worth their price
Transmission: 4l80e
Axle/Gears: 3.512
Transmission: 4l80e
Axle/Gears: 3.512
yeh, I didn't notice the length of springs; Kingtal0n's idea seems clearer than mine, perhaps instead of modifying factory retaining plate it'd be easier to fabricate custom spider held by drilled bolts, or even eight small, single keepers in place of large assembly.
junkcltr
Aug 2, 2019 11:12 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
ambainb
Apr 25, 2016 09:21 PM
MoJoe
Sep 24, 2015 09:12 PM
gixxer92
Sep 1, 2015 04:32 PM
