engine will not idle down inbetween gear changes!!!!!
Old Mar 7, 2001 | 07:47 PM
jody92RS's Avatar
I have a 1992 and when I change gears or come to a red light the throttle is very slow to come back to a regular idle. It hangs up at about 1500 rpms, after 10 or so seconds it will finally start to slowly come back to around 750 rpms. Anyone have any suggestions???????
Jody
1992 25Th Anniversary Camaro
305 TBI
5 Speed
Old Mar 7, 2001 | 08:12 PM
ryansell's Avatar
I had this trouble with my 90 Formula, 5.0TPI, 5 speed. Have you tried reving the engine to get it to drop back down to idle? It could be the bushings in your throttle body. I eventually had to replace the whole throttle body. You might need a new TB, but hopefully not. See if a quick rev with fix it.
Old Mar 7, 2001 | 08:14 PM
jody92RS's Avatar
I have tried a quick rev and that does not work.
Jody
Old Mar 8, 2001 | 02:58 PM
jody92RS's Avatar
BTTT
Old Mar 13, 2001 | 04:18 PM
84TransAm's Avatar
Maybe try a new acellerator cable?
--Steve S--
1984 Trans Am 305 LG4, 5 speed
Daily Driver, Flowmaster 80 Series
Holley 600 cfm & vacuum advance
Old Mar 13, 2001 | 06:53 PM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
My car does the same thing, but only for about 1-3 seconds. However mine only does it when the car is MOVING. If I'm sitting still, the idle adjusts much quicker.
Since the car started acting this way after I installed my open air filter, I figured the idle stays high due to the increase of air getting into the engine.
If you've never checked out your engine..take a look at your throttle cable and linkage, fuel pressure (not enough fuel), and the IAC motor. These parts would create a condition where you are getting too much air and the engine is trying to compensate with a high idle in order to get the proper mixture. Just my $.02
92 Camaro RS LO3, 5-spd, T-tops
Performance:
SLP 1 3/4" Headers (Coated by Paul Barry Motorsports), Flowmaster Catback Exhaust, Fastchip Performance PROM, Centerforce Dual Friction Clutch, Xact 8mm wires, Open Air Element w/K&N Filter, Z28 Grille w/aftmkt fog lamps
Electronics:
Alpine 8030 Alarm System, Valentine One Radar Detector (How did I ever drive without one?), Pioneer DEH 7450 Head Unit w/6-pack CD changer, Pioneer DEQ 7600 Sound Processor, 2 Kenwood KAC-846 Amps powering 2 12" Pro Red subs, 2 Pioneer 6x9 and 2 MTX 4x6 speakers.
NEXT UP: TBI mods, Edelbrock performer intake
Old Mar 13, 2001 | 07:21 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
I doubt this has to do with any kind of bind since it seems to be common, even across TPI/TBI. Just a WAG, but i'll bet it's your IAC keeping your idle speed high between gear changes to lessen the shock loading of re-accelerating the flywheel after the shift.
But by all means, do make sure that nothing is binding. Easy enough to do, just take off your air cleaner9for teh TBI guy, and watch the throttle linkage while you work the pedal. If you see it lag when you let ot go, you know you've found a problem.
...ed
Ed Maher - Moderator @ The Carb Board
92 Z28 Convertible - Quasar blue / Tan top
LB9 4L60 GU2 G80 - stock, soon to be sleeper
-=ICON Motorsports=-
- Definitely prototypes, high powered mutants of some kind. Too weird to live, too cool to die
Old Mar 13, 2001 | 10:29 PM
D_Amlee's Avatar
Car: 89 IROC
Engine: Yes
Transmission: That, too.
Ok, so I'll be the odd one out. I'm not even going to blame the throttle cable or the TB ... I think you may need to look at your clutch. If the clutch plate is not releasing completely during your shift, the transmission drag will try to keep the engine revs up. This used to happen to me years ago on an old 2nd gen of mine until I got the clutch adjusted correctly.
89 IROC with lots o' stuff
specialized
Jun 18, 2022 09:26 AM
jklein337
Sep 19, 2018 06:23 PM
backtothe80s
Sep 5, 2015 12:39 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
mizz0313
Aug 12, 2015 06:45 AM
