Who's running 12's?
Old Mar 16, 2001 | 12:35 PM
mustangs killer's Avatar
Who's running 12's?
I was just wondering who was runing in the 12's and under and what it took to get there. I figured I could pick up some valuable info this way. Thanks
Old Mar 16, 2001 | 12:49 PM
Willie's Avatar
Car: 1987 Z28 Convertible
Transmission: 5-speed
I had to prove that a 305 could do it. This year, I hope to be in the 11's.
Willie
Supercharged 1987 305 IROC-Z, Daily-Driver, Emissions-Legal.
Paxton (6-psig): 12.57 @ 111 mph.
Paxton (6-psig) & 50-hp nitrous: 12.04 @ 114 mph.
ATI D1SC (10-psig): ?
http://willie.camaro-firebird.org/
1987 "20th Anniversary Commemorative Edition" Z28 Convertible -- Super Chevy Show Class Winner, 1998.
Old Mar 16, 2001 | 12:56 PM
Steve89GTA's Avatar
Will, your car is what I want mine to be eventually...I'm just saving up for a good rebuild with a strong bottom and some world products heads. Then, it'll be ATI time.
wicked car man!
89 GTA G92
305 TPI WC 5spd w/3.45
Accel Cap & 8mm Taylor's
Custom 4" Cold Air Induction
Jet Airfoil
K&N Airfilter
160 deg stat/fan switch TB Bypass - Steel Rad
Cat back 3" Exhaust w/Terminator Muff.
HiGh FlOw Dynomax Cat
Spohn LCA's - KYB GR-2's
Moroso Crank Bolt and roller pilot bearing.
Autometer Vac+Oil Temp
Old Mar 16, 2001 | 02:25 PM
BadSS's Avatar
It took a lot of time and work to get the wife’s IROC to turn the times run in the sig. 12’s are pretty easy if you can run a carb and the emissions laws are not that strict. What induction system CAN you run,, and what are you leaning towards?
86 IROC - 9.8:1 - 355, TFS twisted wedge heads, 218/228-110, fully ported GM base and plenum, SLP runners, 52mm BBK, 24# SVO, 88 350 GM EPROM, 1 5/8" Headman headers, 2.5" Dynomax, TH350, 2200 stall, B&M Megashifter, 3.23 peg leg, 245/45ZR17 on 212 Eagles - Best run - 12.53/112.4 on 26x11.5 ET Streets.
Old Mar 16, 2001 | 03:16 PM
Blade's Avatar
I hope I can do 12s with the new heads and intake
92 Z28 5.7
Trick Flow 23° heads, Comp Cams XR270HR-10 cam, Accel intake base + ported TPI,
TES headers, Flowmaster catback, MSD ignition, #24 SVO injectors, 1LE aluminum driveshaft.
Click here to see pics of my car.
Check out our car club Truspeed
Check out the Bin Archive for all your .bin needs
Old Mar 16, 2001 | 04:49 PM
Birmass's Avatar
I'm pretty sure I can get in to the high end of the 12's right now. If I can just get some traction I should be even better. Once the track opens I'll have time to really see, but as of now, I haven't lost a race to an LS1 yet. And yeah, it's TBI. Check my sig.
88 firebird formula
350 Vortec TBI
214int/224exh, .471int/.491exh
Edelbrock headers
SIX-speed
open 3.73's
2 1/4 stock catback
I love pissing those LS1's off
My Formula
All your base are belong to us.
Old Mar 16, 2001 | 05:22 PM
Willie's Avatar
I should have mentioned that the first time I ran my car at the track (bone stock), my times were 15.90's at a whopping 82 mph. I've almost taken four seconds off since then.
Willie
Old Mar 16, 2001 | 05:39 PM
'87FAKE-IROC-Z's Avatar
Car: Damn
Engine: This
Transmission: New Stuff
Willie, I love your car.
nough said.
'88 RS (originally 2.8)
New 350, .040 over, ported vette L98s, ported stock tpi.
Old 305 injectors & chip
TES headers, 3.73 gears, 700r4.
Best with 2.8-17.4@77mph
Best with 305-15.0@93mph
Best with 356-13.7@101mph
(Damn the 2.8!)
Old Mar 16, 2001 | 10:05 PM
TTA's Avatar
TTA
Gut the Cat, Change the Chip, Up the Boost 12.21@112 on Radials. It was hard
Mike
1989 Turbo Trans-Am
11.25@121.25
Only had the valve covers off once... 106K miles and still going. 300+ Runs.
1998 Trans-Am LS1 6 Speed
13.10@106 Bone Factory Stock
Old Mar 17, 2001 | 12:38 AM
20-psi's Avatar
Me too, 12.42 on street tires with the TTA. The mustang slowed to 12.08 after switching to a C-4 on motor but 10.97 on the juice 1.49 short time.
Pete
Old Mar 17, 2001 | 06:17 AM
Nitro Don's Avatar
Hey Willie,
I hope to beat you to the 11's this spring.Still using the stock bottom 305.
After I get this head problem fixed,Im there.
I'll go out on a limb and say "DEEP IN THE 11'S!!"
Nitro Don
Old Mar 17, 2001 | 07:38 AM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
<font face="Verdana, Arial" size="2">Originally posted by BadSS:
</font>
BadSS, please contact me about your car. We have a simular combo and I can only manage a 13.7@103mph this is with a 2.1 60' time.
I need to know what's holding me back from hitting the 12's that is my goal and I will stop when I hit that target. My car is a daily driver with an average of 40 miles a day driven.
Do you have a web page so I can read more about your wonderful car?
86 Camaro Sport
383 Speed-O-Motive Crate Engine, Trick Flow Twisted Wedge G2's, 58mm Accel TB, 3.73 Auburn Pro, SLP Cold Air Induction and Headers, Dynomax Cat-back, Serpentine Belt Setup, Dual IROC Fans, Jamex springs, 16" IROC Rims, 36mm/24mm Sway Bars, Global West Steering Brace. Hotchkis Rear LCA's,Panhard Bar and SFC's.
My Camaro Project
Old Mar 17, 2001 | 08:09 AM
Willie's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Nitro Don:
Hey Willie, I hope to beat you to the 11's this spring.</font>
A little bit of friendly competition never hurts anyone. Good luck, Don.
I also have a couple of issues to resolve before I race again. Ultimately, my goal with the D1SC is to produce 15 psig boost. Currently, I'm at 8 BUT I see that I'm running lean (700mV O2) over 5 psig. So I installed the Carroll Superfueler. If you're not familiar with this setup, it adds three supplemental injectors that straddle the top of the plenum. Fuel is injected via a plate sandwiched between the throttle body and plenum (similar to a nitrous plate system). When I installed the Superfueler, I had a rude awakening -- I have clearance problems between the injector electrical connectors and my hood!!! I just ordered a cowl induction hood. This will take four weeks to fabricate since I'm having custom work done to it -- it will have an enclosed raised area so I can mount an SS style air filter box on top of the plenum. I really don't like the fact that the ATI kits place the cone-shaped air filter above the driver's side header. The "new" air filter will draw air through a sealed rectangular hole in the hood allowing the cowl area to serve as a fresh air intake -- no more engine compartment air into the supercharger. Take a look at featured car in the May 2001 issue of Super Chevy. Someone took my idea and built it already!!!
Once I get the hood, I'll have the tweak the ten setpoints on the Superfueler. Then I change the blower pulley and do it all over again. Then I'll be ready!!
Willie
[This message has been edited by Willie (edited March 17, 2001).]
Old Mar 17, 2001 | 09:09 AM
b9radz's Avatar
My 17yr. old son ran 12.78 his first time at the track with two practice runs.
Street tires
No fans---no juice !
My sons car: 86 Iroc,388ci,Brodix,Victor jr,TPI-700r4,3:73.
Old Mar 17, 2001 | 01:06 PM
pat85yellowroc's Avatar
blade, where did you get your white face guages at?? i would like to get some of those for my 91z.
Old Mar 17, 2001 | 01:42 PM
Blade's Avatar
Macewen !
eightsixseven
Dec 16, 2024 01:50 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Fast355
Dec 2, 2016 06:33 PM
perZ
Aug 21, 2015 05:51 PM
ezobens
Aug 19, 2015 10:29 PM
