Where is this water coming from?
Old Mar 15, 2001 | 09:17 PM
84CAMAROHIGHOUTPUT's Avatar
My L69 305 has a bad water leak somwhere, it leaks on the exhaust Y pipe and is very hot.
I have replaced both radiator hoses and water pump, my radiator shows no signs of any leaks. Where else can this be coming from?
Old Mar 15, 2001 | 09:20 PM
Steves ZZ5's Avatar
Sounds like a freeze plug. Or maybe and quite possibly one of your heater core hoses
86 Trans Am WS6 Black with tinted windows, shaved door handles
ZZ4, Mini-ram, true duals
***Too many other mods to mention***
"In the future, cities will become deserts,
roads will become battlefields, and the hope of mankind
will appear as a stranger"
The Road Warrior
[This message has been edited by Steves ZZ5 (edited March 15, 2001).]
Old Mar 15, 2001 | 09:24 PM
gruveb's Avatar
Car: 1989 IROC-1
If it leaks on the Y pipe, then look around the back side of the intake manifold, or maybe a heater hose or even one of the heater hose pipes? Things like this can be a real pain, but it's just a matter of searching patiently.
Old Mar 15, 2001 | 10:49 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
I agree with the freeze plug idea.
There are 2 at the rear of the block also, between the engine and transmission.
Hopefully its not one of those.
Take a good look, maybe have it pressure checked and make sure where its coming from.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
R.I.P. #3
My favorite quote about D.E. "He can see air"
[This message has been edited by Engineboy (edited March 17, 2001).]
Old Mar 16, 2001 | 10:12 AM
Beefy89's Avatar
If it's a freeze plug than I'd bet there is more than one bad one.
We need Perry Mason
Old Mar 16, 2001 | 09:28 PM
thanks everyone, the heater hoses are capped off at the water pump and intake manifold so it can't be that. are freeze plugs expensive to repair?
Old Mar 17, 2001 | 10:18 AM
Engineboy's Avatar
Car: yep
Engine: uhuh
It depends on what one or more are leaking.
If its the ones in the rear of the engine, you have to remove the trans to get to them.
If its under the motor mounts, they too are a PITA.
1999 NBM Trans Am
1981 corvette
1995 Kawi ZX6R
R.I.P. #3
Old Mar 17, 2001 | 12:21 PM
SUPER-SPORT-CHEVY's Avatar
No No No the last post before mine is incorrect you do not have to take the trans out there is no freeze plugs by the rear main . Before you spend some cash at the garage try gettting a vile of aluminum seal its 3 bucks and could stop your leak for a while or all togather.
Old Mar 17, 2001 | 02:28 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
<font face="Verdana, Arial" size="2">Originally posted by SUPER-SPORT-CHEVY:
No No No the last post before mine is incorrect you do not have to take the trans out there is no freeze plugs by the rear main . Before you spend some cash at the garage try gettting a vile of aluminum seal its 3 bucks and could stop your leak for a while or all togather. </font>
Umm...for lack of better words...wrong.
I've been replacing those freeze plugs that "don't exist" above the rear main for over 15 years.
There are 2 freeze plugs back there. Trust me, I'm looking at 3 SBCs right now in my garage.
1999 NBM Trans Am
1981 corvette
1995 Kawi ZX6R
R.I.P. #3
eightsixseven
Dec 16, 2024 01:50 PM
NiG
Sep 2, 2015 06:54 AM
lakeffect2
Aug 23, 2015 08:44 AM
Street Lethal
Aug 12, 2015 11:33 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
