Pinhole leaK in radiator
Old Mar 16, 2001 | 04:25 PM
88_TAOD's Avatar
So how can i fix this
Is there an additive i can add to seal the leak. Also would a rad from an 85 z28 5.0 305 engine work on my 5.7 gta
1988 Pontiac Trans Am GTA
350 tpi, Fully Stock
BEST ET 15.4
Stereo
Alpine CDA-7864
Power Acoustik Apache Series 2200 watt amp
Two MTX Thunder 8000's in Thirdgen Box
Old Mar 16, 2001 | 04:50 PM
cfabe's Avatar
Bar's Stop Leak might plug up a pinhole leak. I've never used it before, but that is what it is designed to do.
Old Mar 16, 2001 | 04:59 PM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
You might think I'm crazy....but try putting one or two teaspoons of black pepper in the radiator. I had an argument with a buddy years ago about it, but sure enough....it worked
92 Camaro RS LO3, 5-spd, T-tops
Performance:
SLP 1 3/4" Headers (Coated by Paul Barry Motorsports), Flowmaster Catback Exhaust, Fastchip Performance PROM, Centerforce Dual Friction Clutch, Xact 8mm wires, Open Air Element w/K&N Filter, Z28 Grille w/aftmkt fog lamps
Electronics:
Alpine 8030 Alarm System, Valentine One Radar Detector (How did I ever drive without one?), Pioneer DEH 7450 Head Unit w/6-pack CD changer, Pioneer DEQ 7600 Sound Processor, 2 Kenwood KAC-846 Amps powering 2 12" Pro Red subs, 2 Pioneer 6x9 and 2 MTX 4x6 speakers.
NEXT UP: TBI mods, Edelbrock performer intake
Old Mar 16, 2001 | 05:03 PM
CraZ-28's Avatar
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
OOOOOOOHHHHHHH YEEEEEAAAAAHH!!!! The old pepper trick. Hahaha. J/K. But seriously, I didn't think that it would work and I tried it and was shocked to see that it stopped the leak. Remember though, this is only a temporary fix until you can get the radiator really fixed or replaced.
'91 Z-28 5.7, SLP 1 3/4 headers, 4 inch Mufflex/Flowmaster cat back, gutted cats, Edelbrock intake, 8.5mm Jacob wires, MSD Blaster coil, S&W subframe setup, Jacob Pro Street Ignition, complete Kenwood system.
Old Mar 16, 2001 | 05:21 PM
ede's Avatar
ede
take the radiator out, clean the hole with sand paper, wire brush, or anything that might work, flux it and solder it with 50/50 solid core solder. if you can't do that take it to a shop and pay someone to do it
ICON Motorsports
1st & 3rd
Old Mar 17, 2001 | 02:12 AM
rhawki's Avatar
Yea, the pepper trick is really cool, at least until you get it flushed. If you don't wanna pull it and solder it, use some JB Weld (clean it REALLY good first). If you do it while the radiator is slightly warm, it will pull it in through the hole a little as it cools down, and will NEVER let go!
-Rich
Old Mar 18, 2001 | 12:35 AM
slickrock55's Avatar
Car: 82 Trans am
Engine: Twin turbo 350
I saw Mcgyver fix a radiator with an egg before, but hey, thats your call . .
Old Mar 18, 2001 | 11:38 AM
Vader's Avatar
<font face="Verdana, Arial" size="2">Originally posted by slickrock55:
I saw Mcgyver fix a radiator with an egg before, but hey, thats your call . . </font>
Wouldn't the shell be tough to get past the water pump?
Later,
Vader
"I'm'a do Things My Way - It's My way or the Highway."
Adobe Acrobat Reader
Bubbajones_ya
Jul 6, 2024 08:32 PM
sac92transam
Oct 7, 2015 02:31 PM
Stryker412
Sep 20, 2015 06:59 PM
84redta
Sep 19, 2015 09:58 AM
blackandblue02
Sep 10, 2015 08:19 PM
