Oxygen Sensor Replacement
Old Mar 17, 2001 | 03:47 PM
KeithO's Avatar
I am trying to replace the oxygen sensor on my 88 IROC with the 5.7TPI motor. I've tried various means to gain access to the current sensor but I can't seem to get a wrench on it to get it out.
Has anyone encountered this? If so, how did you get the sensor out?
Old Mar 17, 2001 | 04:33 PM
FormulaKid's Avatar
Car: 1989 Firebird Formula
They make a special socket for this...Not everyone uses it, but I have used it and it easily removes the sensor. Jc Whitney sells it. Do a search on thier web site...or your local auto parts store might also it.
Old Mar 17, 2001 | 04:54 PM
ede's Avatar
ede
yeah use a socket way easier, plus if you have to buy the socket you get another neat tool to add to your collection.
ICON Motorsports
1st & 3rd
Old Mar 17, 2001 | 05:01 PM
KeithO's Avatar
Thanks. I actually considered butchering one of my tools. Now I have the chance to buy a new one!
Old Mar 17, 2001 | 10:44 PM
Vader's Avatar
Keith,
Why butcher a tool that wasn't designed for the job? If you're replacing the sensor anyway, cut off the wire and use a standard 13/16" spark plug socket. When you install the new sensor, coat the threads well with anti seize compound and use a standard open end wrench.
Later,
Vader
"I'm'a do Things My Way - It's My way or the Highway."
Adobe Acrobat Reader
Old Mar 17, 2001 | 11:09 PM
Hecubus's Avatar
Car: 91 z82
Engine: 5.0
Transmission: pro-built 700r4: 2400 stall
I picked up a socket the other day for $11 at Auto Zone works great
Hecubus
http://www.tweak3d.net/temp/z28.jpg
Old Mar 18, 2001 | 08:46 AM
KeithO's Avatar
Ahhh... Vader, you saw my dilemma. I didn't know there was a special tool for this and I couldn't get the open-ended wrench of the correct size into the area. So, I was going to cut my open ended wrench to fit... I now will simply buy this socket (I assume that's what it is).
Bosch was nice enough to coat the new sensor with anti-seize for me.
Old Mar 18, 2001 | 08:47 AM
KeithO's Avatar
Vadar - Also, I did try my spark plug sockets, but they weren't deep enough. I even pulled the rubber out of them...
Old Mar 18, 2001 | 01:02 PM
rezinn's Avatar
Make sure you get the old one warm, that anti seize is strong stuff. Running the engine for a few minutes will do it, just dont burn yourself on the exhaust.
bamaboy0323
Sep 3, 2015 06:07 AM
beast94
Aug 20, 2015 06:44 AM
91REDZ28VERT
Aug 18, 2015 10:16 PM
92purpz28
Aug 11, 2015 02:30 PM
