rev limiter?
Old May 9, 2004 | 04:02 AM
mrgoodwrench's Avatar
Car: 91 trans-am
Engine: 5.0 tpi
rev limiter?
I have a 91 trans-am, tpi, 305, and i just recently put a newly rebuilt and modified engine into it, acording to the ppl who built it, i shoud easly be able to take it up to 7000 rpm, but when it gets upto around 5300 it like dies out and just doesnt feel like it wants to go whether its in gear or park, what could be limiting it? thx
Old May 9, 2004 | 05:02 AM
DauntlessZ28's Avatar
Car: 1984 Z-28
Engine: L69
Transmission: 700-R4
I'd imagine it's the rev limiter. Sure it could probly be able to withstand 7k rpm, but do you really need to go higher than 5300? At full throttle, my 305 shifts at about 5k.
Old May 9, 2004 | 09:08 AM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
I assume by your profile you have the stock TPI manifold on. If so there's your "rev limiter".
Old May 9, 2004 | 11:06 AM
CaptPicardsZ28's Avatar
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
Re: rev limiter?
Rick is right. Doubt you'll take anything to 7000rpm with tpi. Mine maxed out at 4500 even after it was ported. According to the people who built it? I assume it's still a 305? Tpi systems will flatline from 4500 to 5200 rpms. Thats why I switched to HSR.
Old May 9, 2004 | 12:47 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
yup they are right if your running a TPI setup.. you arn't going to make any sort of useful power above 4500 or so.. if your running a cam that has a powerband up to 7k its very likely that it doesn't start making power until around 2500 of so.. if thats the case you need to look into a alternate form of induction as its simply not going to happen with a long tube runner system like a tuned port setup..
Old May 9, 2004 | 01:43 PM
Car: 91 trans-am
Engine: 5.0 tpi
Thx everybody, kinda disapointed but What is HSR?
Old May 9, 2004 | 01:46 PM
todd200's Avatar
Car: 87 IROC-Z
Engine: 350ci
Holley Stealth Ram
http://www.holley.com/HiOctn/ProdLin...FMS/SR/SR.html
Old May 9, 2004 | 02:54 PM
Try www.stealthram.com. See my pic. I have HSR.
Old May 9, 2004 | 08:10 PM
TheMysticWizard's Avatar
Car: 1987 Firebird Trans AM
Engine: 383 TPI...very soon
Transmission: TH700R4
My 305 will rev up to about 5700, but I don't think it is making much power up there. If this odd? Runners and base are stock, ported plenum.
Maybe my tac is way off?
RedLeader289
May 28, 2019 01:47 PM
Ed1LE
Sep 30, 2018 09:14 AM
jrdturbo
Mar 31, 2016 02:58 PM
racereese
Oct 3, 2015 03:46 PM
drumstixer
Sep 29, 2015 03:02 PM
