stock hood
Old Mar 19, 2001 | 09:44 PM
mustangs killer's Avatar
stock hood
I can't afford an aftermarket hood so is there anything I can do to my hood to reduce heat and increase air-flow. I also want to look good. If not, then I guess it will have to wait until next year. Thanks
Old Mar 19, 2001 | 10:49 PM
idrag2's Avatar
You can go in on the back side of the hood and remove the weather striping as we all know there is a lot of air that stays at the bottom of the windshield. So you might as well put it to a use. This will also be a good sorce of cold air. Hope I helped?
I Drag 2
Old Mar 20, 2001 | 12:38 AM
vortecfcar's Avatar
Car: '98 Z
Engine: LS1/6
Transmission: 4l60E
check my hood, L88 scoop painted and double sided taped/riveted to the stock hood with large hole in it. total 120.
PS its in the sig
91 RS W/carbed 350, Vortec heads, performer rpm, Comp cams Xtreme energy 224/230 duration and .477/.480 lift. BFG Drag radials. 3.42 posi,Corvette servoed 700r4, 3000 stallconverter. Edelbrock TES, 3inch cat, flowmaster with single 2.5 inch exit.
Best time yet to come
12's?? :crossthumbs:
This is a Pic of my car in race trim www.tbns.net/billyjay/camero.jpg
Yes I know how to spell camaro- so dont ask. I didnt make the link
Old Mar 20, 2001 | 07:14 PM
I ripped the linning out tonight. That should help some. I was wondering if anyone has put vents in the hood. Like where the cut outs are already inside the hood. I was thinking about putting on on each side in the rear of the hood. What do you think. I'm open to options. Thanks
Old Mar 20, 2001 | 07:28 PM
rondubbs's Avatar
<font face="Verdana, Arial" size="2">Originally posted by mustangs killer:
I ripped the linning out tonight. </font>
um, if your talking about the insulation you better put it back in, unless you want the paint on your hood to fade.
Old Mar 20, 2001 | 08:34 PM
87RS402's Avatar
<font face="Verdana, Arial" size="2">Originally posted by ron rizzotti:
um, if your talking about the insulation you better put it back in, unless you want the paint on your hood to fade.</font>
Hogwash.
https://www.thirdgen.org/messgboard/...ML/006865.html
Old Mar 20, 2001 | 10:13 PM
The paint won't fade. The hood gets hotter sitting in the sun all day. That's a bunch of BS. My engine only gets to a max of 180 degree's . Have you ever took the hood temp of a black hood thats sat in the sun all day. The main purpose of the lining is to mufful the engine sound. Does anyone have any useful info. Thanks
Old Mar 21, 2001 | 02:44 AM
ihateallmustangs's Avatar
I vented my L88 hood on my 89 rs and the temp. dropped 5 degrees. I now run a constant 185. and didnt need to remove the entire hood lining, just where the vent hole is. putting a vent in the proper place on your hood will drop the temp.
Old Mar 21, 2001 | 09:54 AM
rondubbs's Avatar
The paint won't fade. The hood gets hotter sitting in the sun all day. That's a bunch of BS. My engine only gets to a max of 180 degree's . Have you ever took the hood temp of a black hood thats sat in the sun all day. The main purpose of the lining is to mufful the engine sound. Does anyone have any useful info. Thanks</font>
yea i got some useful info, your original question was "is there anything i can do to my hood to reduce heat and increase airflow?" first off itd be nice to know what type of car you have, because different f bodies have different hoods.. if you have a formula you can open the vent on the hood to let heat out .. if you have an iroc or trans am you can open the louvers BUT it will not draw air into the engine compartment, you need a 3 inch cowl to do that..
why are you doing this anyway if your engine only gets to a max of 180*??
Street Lethal
Apr 30, 2019 12:14 PM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
Randomtask2
Aug 13, 2015 01:57 AM
bryan623
Aug 10, 2015 11:33 AM
