Need Short Plugs
Old May 11, 2004 | 02:41 PM
VetNutJim's Avatar
Car: Different One Every Day
Engine: LS1,LS6,L98,L83
Transmission: 700R4, 4060E,Turbo 350, Turbo 400
Need Short Plugs
Got a couple of plug wires too close to my headers.
Anybody know the Accel Shorty Plug Number that is equivalent to a R45TS ?
Old May 11, 2004 | 02:54 PM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
any parts store can tell you.
Old May 11, 2004 | 07:14 PM
VetNutJim's Avatar
No part stores here that would even know what an Accel Shorty plug is.
They would think it's a water jacket plug or something.
Headers? What's that? A title at the top of the page.?
These guys are so lame they crawl to work at the part stores around here.
Anybody?
Old May 11, 2004 | 07:56 PM
Engine: 406
remind me never to break down in COlumbus,Ga.
Try www.Summitracing.com
ACC-8197
ACC-8198
ACC-0576S
ACC-8199
Not sure wich one crosses over but these are your choices..if you call summit tech line they can help you.
Old May 11, 2004 | 08:03 PM
TA5LiterHO's Avatar
Car: 1984 Trans Am WS6
Transmission: 700r4 Highly Modified
Go with the Accel U Groove header plugs. Much more clearance and they work excellent. You can get them at Advance or Jegs or Summit.
Old May 11, 2004 | 08:12 PM
Engine: 406
ACC-0576S
Old May 11, 2004 | 10:13 PM
VetNutJim's Avatar
Fantastic!
I'll surf and swerf and find them.
Thanks.
Old May 12, 2004 | 09:34 AM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
Definitely the U-groove shorty header plugs. I'm using the 574's (the 8-pack number is #8198), which are the colder plugs equivalent to the Delco 43TS or 44TS. I think the next warmer plug is a 576 (8 pack is #8199), which will probably match up with the 45TS Delco plug.
The 8199 pack is available in all the O'Reilly stores around Dallas, but you can always order them from Jegs or Summit, too.
Just pick your heat range to see which one of the 2 you want/need.
Have a Great Day!!!
Old Jul 31, 2004 | 08:17 PM
slowTA's Avatar
Car: '88 Formula
Transmission: T-5... in need of slight rebuild
What is the difference between the 574/576 and the 276? I have a set of 276s now and have to replace them. I'm using dart Iron Eagle heads (straight plug) along with SLP 1-5/8 headers. The heads require '.460” reach, tapered seat, Champion V59C / V59YC.' The clearance is so bad I burn a plug wires constantly, even with the shorty plugs the boots are almost touching. I'm actually going to consider cutting out the bend that is touching and welding in another, larger bend!!
Old Aug 1, 2004 | 10:49 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
I just went through the whole accell shorty plug idea and to make a long story short. Get the Autolites or the NGK plugs. They are the same length as my shorty plugs and much much cheaper. The accell plugs fail quickly. On my 406 I had so many problems getting the car to run and turned out that a mechanic of 30 years checked my plugs with a multimeter. One end to the tip of the plug and the other to an engine ground. There was continuity between the tip and the ground strap causing the current to ground out to the block. So I tried cleaning these still clean plugs and still the same thing. I ended up getting Autolites and now my car runs right. This is personal experience and not some rumor. The guy at O'reilly's warned me about the plugs before I bought them but I didn't trust him. He looked only about 16 or 17 years old. I have worked on cars nearly that long. Anyway, Please don't get the accell's. You'll be sorry.
Old Aug 1, 2004 | 10:51 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
I just noticed that this thread was started in May. What did you end up doing about plugs?
Old Aug 2, 2004 | 06:10 AM
slowTA's Avatar
Car: '88 Formula
I brought this post back from the dead instead of starting a new one. You wouldn't happen to have a part number for the autolite or NGK plugs? Something tells me that I'm going to have a hard time finding plugs this short unless I know the number. Thanks.
Old Aug 2, 2004 | 09:53 AM
vernw's Avatar
I'm using the NGK UR5 (plug #2771) in my 383 with iron Sportsman II heads now, gapped at .050" with my MSD Dig 6+ and MSD coil. That the equivalent of the Delco R43T plug, which is one step colder than stock.
My Accel's loosened up the tips and started missing out as well......
- Vern
Old Aug 2, 2004 | 10:05 AM
mykxt202's Avatar
Car: 82 z28
Engine: 400ci 450hp
The accels are the same plug as the Nippendenso U-Groove's
Old Aug 2, 2004 | 11:24 AM
slowTA's Avatar
Car: '88 Formula
FYI the difference between the 200 series and the 500 is that the 500's are resistor plugs, thus more expensive.
I'll have to keep an eye out of some different shorty plugs based on what everyone else is saying about them.
Old Aug 2, 2004 | 11:45 AM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
Bosch single prong platinums are also as short as the Accels and last a LOT longer. I'm into the fourth year on mine and it runs like a top, pulls down 19.5 mpg in the city and starts at -25* Celsius
Old Aug 2, 2004 | 04:11 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
Advance Auto Parts can cross reference brand to brand.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
86CamaroDan
Sep 29, 2015 10:08 PM
TheTraut88
Sep 11, 2015 05:16 AM
64goatman
Sep 9, 2015 01:09 PM
90formulaVortec
Sep 3, 2015 09:26 AM
