Air pump
Car: 92 Z/28 Convertible
Engine: LB9
Transmission: Mad Dog Auto 700R4
Air pump
Ok, how do you get the pully off this thing?? 3 bolts, no mystery, but I can't figure out a good way to kee the thing from spinning while I undo them.
Any suggestions??? Please be nice, this is the first time I have dug this far into an engine!!
Axle/Gears: 9-bolt/3.45
OMG, no!
I hope you were joking with him. It's only held on by the three bolts. But if you know of a safe way to do it with a pry bar, please elaborate, lol.
Scanman, I'm assuming the air pump is off the car? I've done it the good old fashion way, lol... you should be able to get two bolts off easily using two wrenches. You'll loosen one while tightening the other. You'll be turning the wrenches/bolts in opposite directions and the same time. That'll hold the pulley steady. So after you get the first one off, do that again on the two remaining bolts, which will get the next one off. Then the last one will be tough--especially cause you've just tightened it up even more to loosen the other one, lol.
Ok everyone, stop laughing!!!
I'm sure there's a better way to do it or even a tool with which to do this, but this is the best way I came up with given my tools, lol.
So for the last one, you'll just need to find something, anything, that you can get a good grip on the pulley so it doesn't spin while you try to loosen that bolt. But be sure whatever it is doesn't damage the pulley. Between the knees probably won't work in this case, lol. If you've got a friend, have him try to hold it tight with both hands while you turn the wrench. If not, then you're back to looking for something to grip with. That'll be up to you.
I hope this helps, or at least was entertaining, lol.
I hope you were joking with him. It's only held on by the three bolts. But if you know of a safe way to do it with a pry bar, please elaborate, lol.Scanman, I'm assuming the air pump is off the car? I've done it the good old fashion way, lol... you should be able to get two bolts off easily using two wrenches. You'll loosen one while tightening the other. You'll be turning the wrenches/bolts in opposite directions and the same time. That'll hold the pulley steady. So after you get the first one off, do that again on the two remaining bolts, which will get the next one off. Then the last one will be tough--especially cause you've just tightened it up even more to loosen the other one, lol.
I'm sure there's a better way to do it or even a tool with which to do this, but this is the best way I came up with given my tools, lol.So for the last one, you'll just need to find something, anything, that you can get a good grip on the pulley so it doesn't spin while you try to loosen that bolt. But be sure whatever it is doesn't damage the pulley. Between the knees probably won't work in this case, lol. If you've got a friend, have him try to hold it tight with both hands while you turn the wrench. If not, then you're back to looking for something to grip with. That'll be up to you.
Car: 1989 TTA
Engine: LC2
Transmission: Worn-out 200R4
Axle/Gears: BW 9-bolt, 3.27's
Maybe a strap wrench woud work well enough to hold the pulley in place, while you turn the bolt with another wrench. Might want to get a rubber or cloth strap wrench, the chain ones may mar the pulley.
Car: 88 IROC-Z
Transmission: TH350
Axle/Gears: 3.45
ah, doesnt really work that well. You need someone else to lean on the bar on the tensioner to make the belt tight enough to hold the pully in place depending on how tight the screws are. Using two wrenches is still the easiest and best way to do it.
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
It's what I did, too.
Belt still on, and just held it tight with my other hand and leaned on those three bolts. I had my pump off and on five or six times trying to pass the smog tests.
Dialed_In
Aug 20, 2015 01:45 PM
mcquigg
Aug 13, 2015 02:26 PM
