Oil pressure drops low... real low
Old May 11, 2004 | 09:57 PM
Crokiller187's Avatar
Car: 89 Camaro RS
Engine: 305 TBI LT-1 Cam/TBI Chip
Transmission: Automatic
Okay well I swapped the cam in the car to an lt1 but now the oil pressure drops at idle from 30 to around 15 psi after its warmed up. It didnt used to do this and I know I have a small oil leak but that shouldnt be the cause of it. Any help.
Old May 11, 2004 | 10:00 PM
Car: 89 Camaro RS
Could my oil pump be going out.
Old May 11, 2004 | 10:02 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
It's not the oil pump.
I'd suggest first making sure you have an oil pressure problem, not a gauge problem. Either just swap the sending unit (those fail real often) or hook up a mechanical gauge and check the accuracy of your stock gauge.
Old May 11, 2004 | 10:04 PM
Car: 89 Camaro RS
Well would I be able to feel the difference in the pressure cause it idles really rough when it drops like that.
Old May 11, 2004 | 10:05 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
No.
I''d suspect that your oil pressure is low because your idle speed is low, not that the idle is low because the oil pressure is low.
Cause and effect; the effect doesn't cause the cause.
Old May 11, 2004 | 10:08 PM
Car: 89 Camaro RS
So how would I change the idle speed. Its controlled by the ECU isnt it. So It would be in my chip that I got that is causing the idle to be extremely low. let me go ahead and thank you for your time and help.
Old May 11, 2004 | 10:12 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Yes the idle speed is controlled by the ECM, via the IAC motor.
Try cleaning the IAC. Then disconnect the battery cable for about 10 minutes, and hook it back up and see if it's any better.
Old May 11, 2004 | 10:13 PM
Car: 89 Camaro RS
Thanx Ill try after school tomorrow. Where is the IAC? Such a noob so little time to learn. Thanx.
Old May 11, 2004 | 10:19 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
on the throttle body
Old May 11, 2004 | 10:51 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Cro, check your email.
Old May 11, 2004 | 11:00 PM
Car: 88 Camaro SC
Engine: SFI'd 350
IAC problems aside, the stock tbis have a pretty slow idle speed, like 550 rpms or so. 15 psi doesnt sound all that unreasonable.
Old May 11, 2004 | 11:02 PM
Car: 88 Camaro SC
Engine: SFI'd 350
Usual way to fix it is to raise the desired idle speed in the prom to around, say 650 or 675.
89GTAOz
May 16, 2020 09:31 AM
355sbcTPI
Aug 19, 2015 04:38 PM
wayshegoes
Aug 17, 2015 12:00 PM
Kaweh
Aug 9, 2015 02:54 PM
