Engine Problems
Old May 16, 2004 | 08:25 PM
Tha_Villain's Avatar
Car: Camaro RS
Engine: 2.8 L
Engine Problems
Hi I am new to this site and i've found it very interesting but i have a problem with my car.
It's Camaro 89' RS with 2.8 L V6 MPFI injection.
I have 3 main problems that I'd like to solve they are:
1. Excessive fuel consumption
2. Very Rough idle or idles very erratically(Sometimes cuts out)
3. Engine has no power
Anybody has an idea what could be a problem??
Thanks!
Old May 16, 2004 | 09:00 PM
Vader's Avatar
Welcome to ThirdGen.org!
There are many possibilities.
Is all required maintenance current? Filters, ignition system, fluids?
Old May 16, 2004 | 09:30 PM
Car: Camaro RS
Engine: 2.8 L
Everything seems to be ok I think it could be something else
Old May 16, 2004 | 09:37 PM
radiateu2's Avatar
ANY TROUBLE CODES
Old May 16, 2004 | 09:40 PM
Car: Camaro RS
Engine: 2.8 L
Yes There are trouble codes one is number 33 other one is 44 and I also have "Check Engine" light on all the time.
Old May 16, 2004 | 10:50 PM
radiateu2's Avatar
ok....now do a search and see what the trouble codes mean and go from there
Old May 16, 2004 | 10:56 PM
johnyIROC's Avatar
The first things I check on 2.8s are 02 sensors and MAF modules... when an 02 sensor goes out, it will do everything you just described.
Old May 18, 2004 | 10:36 AM
Car: Camaro RS
Engine: 2.8 L
The only code I am getting now is 34 i assume it has to do with MAF sensor
Old May 18, 2004 | 12:25 PM
Vader's Avatar
Your assumption is correct. However, the presence of the code doesn't necessarily mean the MAF is faulty. There are many reasons a "34" can be generated with a GOOD MAF.
Old May 18, 2004 | 09:26 PM
Ratchet's Avatar
I had a 350 that did that just because the plugs were bad. I would check that first.
My second choice would be a coil with a crack in it. Open the hood in the dark and see if you see any blue sparks around the coil with the engine running. Happened to my sons 2.8 and a new coil made it run like new.
Third choice is 02 sensor. My cavalier was doing exactly all three things you said and it was the 02 sensor.
I have changed about 3 MAF sensors because that was what the code indicated and each time it was something else. I have actually never seen a bad MAF sensor.
Ric
Old May 19, 2004 | 05:40 AM
ede's Avatar
ede
i'd back up to Mr Vader's first reply. do the tune up maintance stuff so you know you have a solid foundation to start with then scan for codes and look a little deeper into any remaining problems.
Infested
May 22, 2018 11:56 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
zeitghaist
Aug 18, 2015 07:33 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
