PCV=Vacuum leak
Old May 19, 2004 | 10:03 PM
88TPI406GTA's Avatar
Car: 2009 Pontiac G8 GXP
Engine: LS3
Transmission: 6L80E
PCV=Vacuum leak
On a 91 Camaro I just bought...with a 5.7
There is a chrome breather on the passenger-side valve cover and a PCV hooked up on the front part of the driver side valve cover. There is ALSO on the driver side valve cover, a rubber hose on the back part of the valve cover that is about 9" long...it doesn't connect to anything and is open.
The previous owner said it is a breather too.
It occured to me that this is a big vacuum leak, right? If there is a PCV on the same valve cover as a breather, that is a vacuum leak and could be a source of oil consumption?
Does this make sense?
Old May 19, 2004 | 10:07 PM
AM Racer's Avatar
A PCV is a controlled vacuum leak whether the hose is connected or not. Don't leave the hose open as it can suck debris into the engine as it's unfiltered.
Old May 19, 2004 | 10:11 PM
Engine: LS3
Transmission: 6L80E
That I am aware of...
I have seen either a breather on each side...or if a PCV is used, the breather is on the other side and the air is pulled through the engine supposedly from the breather on the other side (if no leakage past the rings occurs...
This current setup I have never seen...
Old May 19, 2004 | 10:21 PM
AM Racer's Avatar
Someone got lazy, didn't know or didn't care.
Old May 19, 2004 | 11:26 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
There should only be two opening in the valve cover on the driver side. One for the PCV valve which is ported to the intake manifold and one for the oil servicing cap. Are you sure that 9" hose doesn't come off the back of the plenum and go to the power booster on the firewall.
Old May 19, 2004 | 11:30 PM
Engine: LS3
Transmission: 6L80E
Hey Trickster...
I really do know how it is supposed to be hooked up... Fair question though.
Basically this car was a Lo3/700R4 car that was converted to a 5.7 tpi/T-5 car using a DFI 6 setup.
Honest to G o d though, there is a hose coming out what should be the oil service cap...like they took a valve cover with only a PCV type hole, and drilled another hole in one of them, then stuck a breather hose in it.
The $10,000 question still is though...is this considered a big vacuum leak? It is too late for me to be playing with the car, so I will find out tomorrow night after work...just curious with the theory though as I have never seen it routed quite like this...
Thanks for any input...
Old May 19, 2004 | 11:43 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Adam,
Is there a oil servicing cap on that valve cover? If it doesn't, it sounds like they took a spare valve cover from the passenger side and modified it. As far as a vacuum leak being there, yes definitely. That is supposed to be a closed system and any openings in it allow more air into the system.
Old May 19, 2004 | 11:50 PM
Engine: LS3
Transmission: 6L80E
AHHAHA!
I thought so
There is NO oil service cap on either valve cover...they look like stock breather side covers, with the driver side modded(I know from my GTA 350 parts).
The sad thing is that I have worked on quite a few engines...and two knowledgeable car guy friends (not like that kind of friend looked at the car too and didn't really notice it.
The metered air is supposed to come THROUGH the engine and from the breather, so the way it is set up now, it SHOULD be a big vacuum leak.
I promise to post pics as-is...before I change anything...tomorrow. And tell a before/after story if it changed how the car runs...
Old May 19, 2004 | 11:58 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Does this mean I win the $10,000.00?:lala: :lala:
Old May 20, 2004 | 12:03 AM
Engine: LS3
Transmission: 6L80E
That depends on if it helps the car run better...
And yes, though the payout is in Iraqi Dinars...the infomercials say they should skyrocket in value sometime.
Old May 20, 2004 | 04:28 PM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
After reading the way you described it, I assume it was one persons way to make a crankcase evac system. I know most all of us do this with our carbed motors street/strip, but dont know if it'd work well with the computer stuff? I know alot of guys will also take and run a -12 fitting in the fuel pump block off plate and install a -12 fitting in the front of the valve cover and run a hose betrween the 2 to help equalize the pressure on the top and bottom of the motor.
As far as the evac system goes, for street driving we've always had to unhook 1 side. With both hoses hooked the the headers it draws too much vaccum and starts to pull oil through the lines-even with the baffled inserts and dumps it into the collector causing the smokey effect when driving. BUT, it is a sure fire way to keep these sbc from leaking oil.
Old May 20, 2004 | 09:47 PM
Engine: LS3
Transmission: 6L80E
Unfortunately...pluggin the vacuum hose to the PCV valve didn't help anything.
Also, when the engine warms up, I am getting vapors/smoke like crazy from the breathers...
it burns oil all the time...and I got a discount with the idea that I would have to replace the engine...I believe it is due...
I have a few more things to try though...
Old May 20, 2004 | 10:09 PM
AM Racer's Avatar
If you get blowby through the breathers with the PCV hooked up, the engine is spent, period.
bbsr72
Apr 2, 2016 09:12 AM
86IROC112
Nov 27, 2015 09:54 AM
86maro_252
Oct 10, 2015 06:52 PM
ndndndnd
Carburetors
Sep 16, 2015 04:13 PM
3rdgenkindagal
Sep 13, 2015 02:02 PM
