How bad is stock exhaust hurting power?
Old May 21, 2004 | 07:34 PM
rjmcgee's Avatar
I got a question. I have a 350 in an 86 IROC that has been rebuilt with flat top pistons, Pro Topline 200cc heads,Comp 1:6 roller tips, XE274 cam, RPM Airgap, Holley 750 DP. Also has a T-5 and right now a 3.73 rear. Have a 4.10 rear I'm setting up right now. Last thing I haven't modified is the exhaust, because of various reasons it has always been put off for something else. From the manifolds all of the way to the gutted cat and 2.25" I-pipe. The car feels good now.
How much is this holding it back, 20 hp? More or less? I read guys saying that the stock exhaust is holding back their LG4 and I'm kinda like
Also for this setup is the Hedman shorties with the Y-pipe modified and a 3 inch cat back about right? Thanks for any input.
Old May 21, 2004 | 07:57 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
I have allways thought the exhaust system should be the first upgrade unless you are doing everything at once. I can tell that your exhaust system is holding you back big time. I would bet you are loosing way more than 20HP. The biggest single seat of the pants improvement was when I put headers on my car. Allen
Old May 21, 2004 | 08:58 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
I'd guess it's costing you at least 50 HP. Probably more. Maybe ALOT more. HP comes from RPM, and that is precisely what you are losing.
It would be really fun to go get a dyno printout now, and one after headers and a cat and cat-back.
That way, you could tell us all exactly how much difference it makes.
Old May 21, 2004 | 09:35 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Thats what i was going to say, about 50hp or so. After you reach the power limits of the stock exhaust it really starts hurting power quickly. Swap in some headers and atleast 3" all the way back, and you will be suprised at the power increase.
Old May 21, 2004 | 10:17 PM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
Re: How bad is stock exhaust hurting power?
Yes, shorty headers work really well and a 3" intermediate pipe to a high performance muffler will make a huge difference.
Old May 22, 2004 | 02:53 AM
Morley's Avatar
The more power improvements you do to the engine without touching the stock exhaust, the more power it will rob you of.
Old May 22, 2004 | 07:03 PM
rjmcgee's Avatar
Thanks for the info guys. It ran a best of 14.05 @99.7 mph last fall with a 600 Edelbrock and 3.42 peg leg rear. Sounds like there is quite a bit left to get out of it with an exhaust upgrade. Wouldn't mind getting a 12 second time slip with it someday.
Old May 22, 2004 | 07:55 PM
scottland's Avatar
Car: '82 Z28
Engine: 350HO
Transmission: M4
With good flowing exhaust it will probably break into the 12's.
Jeremys87
Jul 14, 2022 09:08 PM
Vintageracer
Jan 10, 2020 05:33 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
db057
Aug 22, 2015 08:17 PM
InfinityShade
Aug 22, 2015 08:00 PM
