Valve Questions, need some help
Old May 22, 2004 | 10:09 PM
Magman's Avatar
Car: 1990 IROC-Z
Engine: 383 HSR
Axle/Gears: 3.70
Bought these AFR 190 heads from a TGO member here a while ago and finally started to prep for install. I came across a couple things that just dont look right.
1. Pic one is obviously a bad valve, top of valve is completely round as compared to the rest and the retainer is gouged. Probally from a rocker adjusted incorrectly. Does this need replaced or will it be fine? If I need to replace, does anyone know where I can get one Manley Pro Flow valve and retainer? Everywhere I have seen sells them in sets of eight.
2. Pic #2 - How do I remove these seals? They seem to be pressed on, should I get rough with them since they are going in the garbage anyway? What is the correct method to remove the seals?
3. Looking in the EXH port, I can see a trail of oil that has leaked into the exh ports,, yes each one of them. Is this indicative of bad seals or is this normal?
Thanks for the help!
Magman's Avatar
Car: 1990 IROC-Z
Engine: 383 HSR
Axle/Gears: 3.70
Pic #2
Old May 22, 2004 | 10:32 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The destroyed valve looks like either a rocker came apart, a push rod bent, or something like that. It looks beyond repair to me.
Those are excellent valve guide seals. They are Teflon; the best that money can buy. They just push on. You can pop them off with a screwdirver or something. You can use the same seals on exhaust guides if you want to; in fact, they are typically sold in sets of 16.
Old May 23, 2004 | 09:42 AM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
You can buy a single valve; summit, jegs ect.. all sell them but I'm fairly sure the retainers are always sold in a set. it would be my prefrence to replace all the retainers since the springs are comming off.
Old May 23, 2004 | 11:26 AM
Magman's Avatar
Car: 1990 IROC-Z
Engine: 383 HSR
Axle/Gears: 3.70
Thanks for the info. I'm going to replace the seals, retainers and the bad valve. Since these heads are milled I'll check the pushrod length also.
Old May 24, 2004 | 12:23 AM
onebinky's Avatar
I know for sure Jegs has the valves individual, I think I paid about $8 ea. for mine. I got the Manley pro stainless valves.
Old May 24, 2004 | 07:41 AM
fastredtruck's Avatar
Car: 88 gmc 1500
Engine: 496
Sure hope there was a shim or something under that spring its real hard to tell in the pic. You need something on aluminum or the spring will dig into the head.
You may be able to get away with just "butting" the end of the valve but they are cheap enough that it should be replaced.
You need a new keeper.
Old May 24, 2004 | 01:43 PM
Magman's Avatar
Car: 1990 IROC-Z
Engine: 383 HSR
Axle/Gears: 3.70
Yes, there are shims under each spring. I ordered a new valve, keepers and valve seals yesterday through Summit. Should be here by Thursday.
Cameeeero
Sep 18, 2015 04:00 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
1985chevydude
Aug 20, 2015 12:29 AM
redmaroz
Aug 16, 2015 11:40 PM
jackhammer
Aug 15, 2015 10:04 PM
