Comp cam Magnum roller tip rocker ?'s
Car: 89 camaro RS
Engine: soon to be juiced built 357
Transmission: turbo 350
are these rocker arms considered roller rockers or stamped stock type rockers...I am confused because my new edelbrock aluminum heads say to use a .100" longer pushrod if using stock or stamped type rocker arms..
Car: 1966 El Camino Custom
Transmission: 200R4
Axle/Gears: 3:73 12 bolt with Brute Strength
Although they are not stamped but investment cast, they are still dimesionally the same as the stamped rockers. My best guess is you'll be needing the longer pushrods. Call Jegs or Summit for a verification.
Transmission: 200R4
I like this guys procedure write-up. Good explanations.
http://www.chevelles.com/techref/ftecref17.html
Car: 89 camaro RS
this is my first engine build and all the parts in my sig are whats going in this weekend...but that write up is pretty helpful thanks...I just hope all goes well.
ambainb
Apr 25, 2016 09:21 PM
LT1Formula
Aug 20, 2015 09:36 PM
