v6 to v8 swap done help with a little problem
Old Jun 2, 2004 | 02:05 PM
br()bert's Avatar
Car: 85 firebird
Engine: Pos 2.8 pulled and replaced with a 350 tpi motor converted to carb.
Transmission: 700r4, vette servo,shift kit, hayden 15"x8" trans cooler.
I went from fi v6 to carbed v8, all has gone well but now i have a small problem, I drove the car for the first time today. It doesnt hook at all, total loss of traction unless i lightly press the gas.(my 225 tires dont help much)
Problem is first gear seems REALLY long! and the shift from 1st to 2nd throws the car sideways hard even if im not on it.
Also, it stalled out on me twice at stop signs.
Could this be a TV cable adjustment thing?
Help guys please!
Old Jun 2, 2004 | 02:16 PM
RednGold86Z's Avatar
Car: 92 Form, 91 Z28, 89 GTA, 86 Z28
Engine: BP383 vortech, BP383, 5.7 TPI, LG4
Transmission: 4L60e, 700R4, 700R4..
Axle/Gears: 3.27, 2.73
Wish I had that problem!!!! Welcome to torque.
How high does it rev? Do you have a V8 tach?
Was there a shift kit in the tranny?
Old Jun 2, 2004 | 02:28 PM
br()bert's Avatar
Car: 85 firebird
I dont have a tach at all, it just seems a little high. VERY low budget swap.
The guy said the tranny had a corvette servo in it and some other stuff i forget.
I guess its cuz im used to the pos 2.8 maybe?
Does the TV cable affect 1-2 shift at all?
Old Jun 2, 2004 | 03:33 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
it sure does, sounds like it needs to be adjusted. If ya don't know how do a search.. its covered on here all the time
Old Jun 2, 2004 | 04:06 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Holley carbs don't quite have the right geometry on the throttle shaft arm for TV vehicles. Continue your search and you'll see what is required to get it right. One of the magazines (Hot Rod, Popular Hot Rodding, or Chevy High Performance - I get all three and forget which one it was) had an article on this very thing within the last year. I don't know if it is posted on their website or not.
Old Jun 2, 2004 | 04:43 PM
br()bert's Avatar
Car: 85 firebird
thanks guys ill do a search and let you know the resultd after i try to adjust it correctly.
Old Jun 2, 2004 | 07:12 PM
br()bert's Avatar
Car: 85 firebird
Ok, I found a site that showed the correct way to adjust the tv cable. I couldnt search here very good (tv two letters) But it turned out where i had the tv cable bracket mounted was too far away from the carbs throttle bracket so the cable was streched too far and too tight.( guy i got the carb from gave me some brackets but none of them fit right) It seems normal now, ill go for a test drive tomorrow and see how it feels.
Thanks everyone.
Old Jun 2, 2004 | 07:13 PM
five7kid's Avatar
Search hint: tv* will find TV.
Old Jun 2, 2004 | 07:15 PM
br()bert's Avatar
Car: 85 firebird
thanks ill keep that in mind
customblackbird
Aug 15, 2021 10:16 PM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
nuggie
Aug 25, 2015 01:27 PM
theurge
Aug 21, 2015 12:46 PM
sreZ28
Aug 14, 2015 07:48 PM
