quench and c/r
Old Jun 4, 2004 | 02:11 AM
cormyr's Avatar
Car: 89 Formula 350 WS6
Engine: 383 miniram
quench and c/r
with a quench of .064" and a 10.5:1 c/r with aluminum heads, flattop pistons, 180 deg thermo, and a 226/226@.050 cam do you think i will have problems with detonation or should this setup be ok?
Old Jun 4, 2004 | 07:49 AM
ede's Avatar
ede
ideal quench is around .040, you're way over that. think i'd reduce head gasket thinckness and try to get it down a little. if the block isn't assembled i'd zero deck it. hard to predict if you have detionation or not, but i'd say with right fuel and timing no.
Old Jun 5, 2004 | 01:41 AM
cormyr's Avatar
Engine: 383 miniram
ok i guess i need to clarify. obviuously i know that .040 is the ideal quench. dunno if you've looked around but none of the aftermarket companies make a piston that is anywhere between -5cc and -12cc. therefore, i have to deal with a not-so-optimal quench. anyone who has built a 383 f/i street vehicle knows what i am talking about. given that, anyone out there who has done this before with decent results?
Old Jun 5, 2004 | 02:06 AM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
What -5cc and -12cc are the most common pistons. -5cc pistons are flatops with valve reliefs and -12cc are a slight dish.
Old Jun 6, 2004 | 11:03 AM
cormyr's Avatar
Engine: 383 miniram
probe industries makes a -12.8cc forged dish. srp makes a -5cc forged flattop. i have yet to find anything in-between.
Old Jun 6, 2004 | 12:04 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
Oops sorry i just reread your post and i'm an idiot. If you need to reduce compression alittle i would grind in the combustion chamber. Get a carbid cutter and a diegrinder and unshroud the valves. Just grind off whatever you need 1cc 2cc, 3cc ...
BTW have you cc the heads to find out what they really measure as?
Old Jun 7, 2004 | 10:34 PM
cormyr's Avatar
Engine: 383 miniram
yep they came in at 63cc. they are lingenfelter fully cnc'd heads so im not into cuting them up with a die grinder.
i guess my real question is how wide can i go on the quench before it actually presents a problem? i've seen posts with guys running .070+ without problems but at a lower c/r. i was wondering if anyone out there has done this with a higher c/r and aluminum heads.
Old Jun 9, 2004 | 01:38 AM
Streetiron85's Avatar
Car: '85 IROC
Engine: LB9
Transmission: 700 R4
I've heard that tightening the quench more than compensates for the increase in CR as far as the octane sensitivity is concerned.
In other words 10.5/1 CR with .070" clearance would supposedly be more detonation prone than 11/1 CR with .040".
That's what some guys say anyhow.
I plan on doing some experiments with that, but haven't had a chance to yet... Sorry
It sounds like a good opportunity for you to do an experiment of your own.
If it pings, it could be an excuse to get a bigger cam.
http://kb-silvolite.com/calc.php?action=comp
The link above is a dynamic CR calculator that might help you to figure it out
Old Jun 9, 2004 | 02:09 AM
cormyr's Avatar
Engine: 383 miniram
check this out btw:
https://www.thirdgen.org/techbb2/sho...ghlight=quench
Old Jun 9, 2004 | 07:03 AM
Car: '85 IROC
Engine: LB9
I couldn't locate this link at first.
There might be some useful info here.
You won't need to do all the math that's detailed on that site since the calculator on the KB site does that for you. But some of the data is still applicable.
http://members.uia.net/pkelley2/DynamicCR.html
And here's a guy who's running flattops with small chamber heads, on his 383. I don't know what he uses for fuel on the street tho
http://www.karl-ellwein.org/383y2001.htm
355tpipickup
Aug 27, 2015 08:13 AM
NWAsonoma
Aug 18, 2015 05:45 PM
TheMysticWizard
Oct 19, 2004 07:00 AM
cormyr
May 14, 2004 11:05 AM
Tom91Bird
Sep 1, 2003 05:23 PM
