ok....i'm driving down the road today and the car just dies. Doesn't stutter or ne thing it juts died........checked oil....full......alt. is new. Sounds like it is not gettin fire......help me figure out my problem
Fuel, Air, Heat(Spark)
Find out which you dont have and your problem will be solved.
Don't forget timing.......Originally posted by dankhound
Quote:
...or compressionOriginally posted by John Millican
Timing on a DIS?
Just rotate the coilpacks to adjust right?
first off, have you checked if it's getting spark or not?
i would pull the ignition module and have it tested. i'm thinking it's dead or on its way out. especially if it just "died" all of a sudden.
what kinda car is this that you're working on? there are also several sensors (cam and crank sensors) that the engine relies on for spark.
Quote:
What kind of car and engine is this that has the DIS?Originally posted by jake_91_rs
Im with you on this one for sure...Originally posted by robertg
