vacuum line question
Old Jun 14, 2004 | 05:16 PM
trueburton's Avatar
Car: '88 Red Trans Am w/ T-tops
The bottom vacuum line that comes off the passenger side of the TB and goes to the Exhaust canister looks as if it is pinched shut at one point. It is like it is being sucked shut though. when i turn off the engine it returns to it's normal state. what would cause this and what kind of weird things may it cause the vehicle to do?
Old Jun 14, 2004 | 05:21 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
You could have a restriction in the line or it could just be getting worn out.
omcrider's Avatar
Car: 1988 GTA
Engine: 5.7L/L98
What causes that is usually old vacuum lines get weak and don't support there shape when the pressure increases.
It will affect any systems its part of by taking away the vacuum feed for that line. Change it out. If its a car you plan on keeping for awhile find the nice silicone ones, they hold there shape over time better and have more strength and resistence to corrosion.
Old Jun 14, 2004 | 05:26 PM
trueburton's Avatar
thanks guys it does look very brittle so i'll go replace it tonight. One more thing. could it cause the car to idle high?
trueburton's Avatar
Old Jun 14, 2004 | 05:29 PM
trueburton's Avatar
thanks guys the line does look very brittle i'll replace it tonight.
one more thing.... could this cause the engine to idle high?
Old Jun 14, 2004 | 05:30 PM
trueburton's Avatar
sorry about that my browser froze half way through sending so i thught it didn't send
Old Jun 14, 2004 | 05:35 PM
omcrider's Avatar
Car: 1988 GTA
Engine: 5.7L/L98
Wow thats one way to get your post count up fast
It could cause idle problems, you might as well replace both those lines one is a 7/32 line that goes to the side of the TB the other is a 5/32 line that connect to a T fitting, one part going to a port on the bottom of TB the other going back to you EGR solenoid.
mdtoren
Aug 23, 2015 12:52 PM
redmaroz
Aug 16, 2015 11:40 PM
mdtoren
Aug 16, 2015 05:45 PM
bamaboy0323
Aug 15, 2015 07:20 AM
apie2546
Aug 10, 2015 05:43 PM
