cam question
Old Jun 17, 2004 | 04:06 PM
92lt1's Avatar
Car: 91z
Engine: 350 vortec
Transmission: built 700r4
Axle/Gears: 373
cam question
im doing a complete motor overhaul and i need some advice. im fairly new to the whole motor world so bare with me. My question is, i have a 89 350 roller motor and im changing everything over to a carb and i ordered a non-roller cam shaft and i was wondering what i need to convert my roller motor to a non roller motor? thanks in advance.
Old Jun 17, 2004 | 04:16 PM
JesasaurusRex's Avatar
First of all send the cam back and order a roller one. People spend a crap load of time trying to find a 350 roller motor. Since you are new to the scene I wont put you down but Im telling you roller is better than flat tappet so do yourself a favor and sell the block to some one that wants it and get a non roller block from the junk yard or make something of that nice block. Hope that helps out.
Now to answer your question if you dont wanna take my advice, all you need is different length push rods, flat tappet lifters, and a different sproket for your new cam. Everything else should be the same. Hope that helps.
Old Jun 17, 2004 | 05:05 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
The Advocate is right. By putting a flat tappet cam in a roller block you are doing nothing more than taking a step backwards in camshaft technology.
Old Jun 17, 2004 | 05:26 PM
YenkoZL1's Avatar
Car: 1991 RS Camaro
Engine: Custom Built 327
Transmission: Tremec 5-speed
DEVILS RIGHT, Roller cam is the only way to go. They're a very reliable cam and hardly gain any wear over time. Stick with the ROLLER setup.
Old Jun 17, 2004 | 06:07 PM
92lt1's Avatar
Car: 91z
Engine: 350 vortec
Axle/Gears: 373
the only reason i have this question is b/c i got the cam from a friend and im copying a engine from chevy hiperformance. with there setup, they made 430 ftlbs and 390 hp. my motor is a 355, flat top pistions making 10:1 comp, i have a mild comp cam in there(215 dur 500 lift) stock vortec heads, edelbrock performer rpm intake, 650 holley, 1 5/8 long tube headers, 3'' flowmaster and k/n of course. i have a built 700r4 with a b/m 2000 stall. if any of you could give me a suggestion on what roller cam you would use to get at least those numbers , let me know. thanks brad.
Old Jun 17, 2004 | 06:19 PM
ZZ4 or LT4 you can get both off ebay for just as cheap as a flat tappet cam.
Old Jun 17, 2004 | 06:25 PM
92lt1's Avatar
Car: 91z
Engine: 350 vortec
Axle/Gears: 373
will that cam give me the numbers i want?
Old Jun 17, 2004 | 08:01 PM
Black 91 Z28's Avatar
Car: 1991 Camaro Z28
You might want to try a LT4 Hot Cam. His setup is similar to yours.
https://www.thirdgen.org/techbb2/sho...ht=vortec+carb
Old Jun 17, 2004 | 08:33 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Dont tell me you bought a USED flat tappet cam.
Old Jun 17, 2004 | 08:47 PM
Yes they both should be right around the same.
Old Jun 18, 2004 | 12:30 PM
92lt1's Avatar
Car: 91z
Engine: 350 vortec
Axle/Gears: 373
i got the cam from my cousin who only broke it in before he developed a rod problem. so your telling my my haudrolic cam is no good.
Old Jun 18, 2004 | 12:32 PM
92lt1's Avatar
Car: 91z
Engine: 350 vortec
Axle/Gears: 373
devil...
your setup is similar to mine, so i was curious what your horse power and torque numbers are and if you have any track times. thanks brad
Old Jun 18, 2004 | 12:43 PM
Id love to bro but I only got the thing up like 2 weeks ago and havent been able to get it dynoed yet. Right now I cant even keep it running after its warmed up. Its weird cuz its getting spark and fuel. I think I have a huge intake leak like I didnt hardly put any silicon around the front and the back of the block. So I took my intake manifold off and put hella black silicon on the front and back. Putting the intake manifold back on this morning Ill let you know. Gonna take it to the track or dyno or both here soon so keep ya posted. Whats ur set up just curious?
Old Jun 18, 2004 | 01:06 PM
92lt1's Avatar
Car: 91z
Engine: 350 vortec
Axle/Gears: 373
its a 92 camaro heritage edition. its white with red heritage stripes. t-tops, cd player, p/w,p/l,p/s. motor you know from the post above. the tranny is a raptor trans with a 2000 b/m stall. the rear is a 373 posi. the suspension is next on the list of things to do. thanks again devil.
Old Jun 18, 2004 | 02:45 PM
Well CHP did like almost the exact same set up should be lil over 400 horses and torque.
Old Jun 23, 2004 | 03:02 PM
92lt1's Avatar
Car: 91z
Engine: 350 vortec
Axle/Gears: 373
well i took yalls advice and bought a lt4 hot cam. now i have a question about the pin in the cam can i use the one from the comp cam in my engine now? should i get different rollers. thanks brad
Old Jun 23, 2004 | 03:19 PM
Um when you say little pin im guessing you are talking about the pin that goes horrizontal with the cam right by where the 3 cam bolts screw into. Yes use that one. Now I dont know what you mean by rollers if you are talking about the roller lifters yes you can reuse those also if you are talking about the sproket for the cam that the timeing chain goes onto yes you can also reuse that. Make sure the timeing marks on the cam sproket match up with the one on the crank sproket. Hope that helps.
Old Jun 23, 2004 | 04:37 PM
92lt1's Avatar
Car: 91z
Engine: 350 vortec
Axle/Gears: 373
devil you got it all correct. thanks a bunch. brad
Old Jun 23, 2004 | 04:51 PM
I do what I can
-Jesse
Old Jun 23, 2004 | 05:51 PM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
To use a flat tappet cam in a roller block just rip off the spider plate and retainers in the lifter valley, throw in your flat tappet cam, throw in flat tappet lifters, get the right sized pushrods, and buy a pre-86 style timing chain.
Although these people may be right you are taking a step backwards sometimes you work with the parts you can find for cheap... nothing wrong with that. Flat tappet motors have been around since the beginning of time there is nothing wrong with them whatsoever. Not to mention they're a ton cheaper and theres more of a selection to pick from. 75% of hydraulic roller cams are designed around EFI motors
Old Jun 23, 2004 | 06:55 PM
YenkoZL1's Avatar
Car: 1991 RS Camaro
92LT1
Look...you already have a Roller setup. A factory Hydralic Roller cam. They do make a Flat Tappet Roller cam as well. And a Flat Tappet Roller cam is one of the most efficient cams around. The only down side to a hydralic Roller cam is that once is gets hot it looses some lift. No joke. But a Flat Tappet Roller never looses lift because...its not hydralic. The cam lobes always hit the lifters the exact same. Basically what Im saying is if you have a roller setup KEEP IT. If not, do what you have to do. But in terms of what type of cam to use. Hydralic for street or street&strip. Flat Tappet I see as more for the strip.
Old Jun 23, 2004 | 07:07 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Yenko:
Flat Tappet Roller
Jumbo shrimp? Military Intelligence? Feminine logic? Masculine sensitivity? A V8 with 5 cylinders? A solid hydraulic?
"Flat tappet" is just that: a lifter whose bottom, where it meets the cam, is "flat". "Roller" is just that: a lifter whose bottom has a little roller, just like a roller bearing. So a lifter can either be flat, or it can have a roller; not both.
Lifters also can either include a little oil chamber for automatic adjustment (hydraulic), or not (solid). You can have a flat tappet that's either hyd or solid; or you can have a roller that's either hyd or solid. Hyd rollers haven't been around long, only a few years before the factory hopped on the bandwagon and botched it.
What are you talking about?
92: you did the right thing; maybe not the best possible cam, but definitely far from the worst. Keep the rollers and take advantage of the improved cam profiles they allow.
Old Jun 23, 2004 | 09:32 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
RB is absolutly correct. "Flat tappet roller" is pretty much an oxymoron. Here's a visual of both:
Flat tappet is on the left, Roller are on the right. Both are the hydraulic versions.
Old Jun 24, 2004 | 03:23 AM
Ya YenkoZL1 imma be the first to say it, keep your mouth shut if you're an idiot thank you.
Old Jun 24, 2004 | 03:29 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Before we go calling names, let him explain himself as to why flat tappet cams are primarily strip cams. This i want to hear.
Old Jun 24, 2004 | 04:00 PM
Damn you Stekman I WANT TO CALL NAMES ALREADY :lala:
beastin91rs
Oct 9, 2015 07:38 AM
SLNTSCPE
Aug 22, 2015 09:15 PM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
Fronzizzle
Aug 9, 2015 01:15 PM
