Weird engine behavior in neutral/park.
Old Jun 25, 2004 | 04:24 PM
StealthElephant's Avatar
Car: 87' Iroc
Recently when I start my car the engine won't rev in park/neutral. I can put my foot down 1/2 on the pedal, the engine will struggle to rev to 2500RPM, and then, with my foot holding at 1/2 throttle, the RPMs will just continue to drop to below 1000 even with my foot still down....only feathering the gas brings it back up. It does this sporadically to me.....once the car is in gear it doesn't do this. Though the engine always seems to want a slight pump as it goes into gear to prevent stalling, but once it's in gear and going, it will idle fine. Just wierd. Any thoughts?
Old Jun 25, 2004 | 05:16 PM
Dr.NickRiviera's Avatar
Car: 1987 Trans Am
Engine: tree-fiddy
hmm, I don't have the hesistation in trying to rev, but mine will stall when i put it in gear if it has warmed up. I'm searching the boards now hoping to find an answer.
Old Jun 25, 2004 | 08:40 PM
z28monster's Avatar
Car: 86 IROC-Z
Axle/Gears: 3.42s/posi/disc
its sound sliek soemthing is binding up in your tranny man id get it looked at before i drive it any more
Old Jun 26, 2004 | 10:59 AM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
It could also be a locked stator in the torque converter.
Old Jun 26, 2004 | 02:56 PM
Car: 87' Iroc
How would that affect the reving problem in neutral?
Old Jun 27, 2004 | 09:41 AM
dankhound's Avatar
Car: 91 RS
If the stator wont freewheel it will resist the flow of the fluid in the torque converter. Its like adding a big load to the engine. Thats why it doesnt rev in neutral.
Old Jun 28, 2004 | 07:40 PM
deadhead1882's Avatar
Car: 82 El Camino
Engine: built 355
Transmission: T-56 upgraded internal
Axle/Gears: 10 bolt 3.42
dr. nick rivera, sounds like it might be your torque converter, i had the exact same problem in a 89 grand am i had, tranny went, got it replaced and cold would be fine, warm it would stall out in gear i had to neutral drop it till i got it fixed and sold it
Old Jun 28, 2004 | 08:39 PM
Car: 87' Iroc
I found my problem, my PCV valve was slowly going out. Finally it just flat out broke, and so it was just letting the PVC port on the carb suck air freely from the outside. Runs fine now.
Old Jun 28, 2004 | 11:09 PM
Car: 1987 Trans Am
Engine: tree-fiddy
Good job in figuring it out.
I had mine looked at by a shop today and they said that it was missing on 2 cylinders when it warmed up, wasn't missing when it was cold thou? I don't have a lot of money to pay them 100's of dollars to replace things like distributor and rotor, or plugs, so i changed them all and am still having the problem? So i guess i'll try new wires, but the ones i have on it have like 50 miles on them.
Old Jun 29, 2004 | 12:23 AM
Car: 82 El Camino
Engine: built 355
check your torque converter as others have suggested
Cleotiz
Jan 6, 2018 08:56 PM
EFR2000
Aug 18, 2015 08:54 PM
sreZ28
Aug 14, 2015 07:48 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
novaderrik
Aug 10, 2015 12:44 PM
