Trouble Starting..
Old Jun 26, 2004 | 01:40 PM
Airpak's Avatar
Car: 1982 Camaro Z28
Axle/Gears: 10 bolt auburn posi 3.73
Trouble Starting..
My car takes like 20 seconds to start if i havent driven it for a day. It just doesn't catch on, i sit there and crank it for a bit n then after like 20seconds it catches on and starts. If i drove it an hour or 2 or 3 or something ago, it starts fine and everything.. Any way i can fix this?
im not to car savvy. thx.
Old Jun 26, 2004 | 01:43 PM
350 TPI's Avatar
I would be curious to know the answer as my GTA does the same thing.Takes forever for it to crank and then smokes for a few seconds.Could possibly be the 9th injector??
Old Jun 26, 2004 | 01:47 PM
Airpak's Avatar
n then i have to hold on the gas for a bit, or it will shut off again, i dont mind that part =D as i get people to stare and whatnot, but the cranking part is no fun =(
mines not fuel injected.
Old Jun 26, 2004 | 01:49 PM
350 TPI's Avatar
I assume you have done the usual wires,plugs,cap and rotor?Also have u checked the timing?
Old Jun 26, 2004 | 02:52 PM
Amrish's Avatar
I had a similar problem with my z28 with a 305TPI... I really didnt know much about owrking on the engine so I was forced to take it to the chevy dealership so why my car wouldnt start but would just keep cranking over and over and eventually start..
My problem was that the plenum was just filled with crap , carbon buildup? and they just cleaned it out and it started to work fine. I had over 150k miles on the engine
Old Jun 26, 2004 | 05:13 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Airpak, how's the quadrajet look overall? Last time it was serviced was?
350 TPI, what color smoke? Black?
Old Jun 26, 2004 | 07:21 PM
350 TPI's Avatar
Red Devil its the oil from the valve seals at startup.But when mine finally does fire it barely runs for a few seconds and then slowly gets up to 750 RPM.It does this if the car sits longer than 15 minutes EVERTIME!!
Old Jun 26, 2004 | 08:13 PM
urbanhunter44's Avatar
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
fuel pump maybe? might be getting old.
or maybe your filter is getting clogged.
just my .02.
Old Jun 30, 2004 | 01:38 AM
CALIROCZ28's Avatar
Car: '98 Z28 LS1
Transmission: 4l60E
Axle/Gears: 373
It is either a fuel or spark problem or both.
For those of you with Fuel injection I would check for a leaking injector or a fuel pump relay also check your timing.
Carburated you might try advancing the timing a bit or check your coil. Could also be a worn Cap and rotor or carbon tracking inside the cap.
mrbird
Oct 20, 2015 03:43 AM
Lmancha96
Sep 25, 2015 08:11 PM
HikoriYami
Sep 21, 2015 07:11 PM
BWilcox
Sep 20, 2015 12:19 PM
eduardosac
Sep 16, 2015 02:18 PM
