Anyone know the cam specs for the '85 LB9?
Old Apr 11, 2001 | 07:04 AM
Kevin Irving's Avatar
Car: 1985 Trans Am
I know they're different than later years, just want to figure out what my lift will be with 1.6 roller rockers that I want to get and see if it's worth it. I want to get away from the stamped steel regardless, and I figure for a few dollars more what can it hurt to put 1.6s in??
Kevin Irving
85 Trans Am WS-6, 305 TPI, custom burned '86 PROM with '87 "165"ECM, Accel Supercoil & 8.8 Wires, MSD 6AL, Aluminum Driveshaft, Wonderbar, TB Coolant Bypass, Ported Plenum, Modified MAF, Syclone Fuel Pump, JET Airfoil
15.556 @ 86.65mph, Nov 10, 2000.... I know it sucks.. but it will get better!
http://www.geocities.com/transam85tpi/
Member - The Tidewater Trans Am Club, Norfolk VA http://www.geocities.com/ttacva/
Old Apr 11, 2001 | 07:53 AM
87kevroc's Avatar
Car: 1987 Chevrolet Camaro Z28 IROC-Z
Transmission: TeamTripp Performance
https://www.thirdgen.org/newdesign/tech/techdb.shtml
Scroll to the bottom.
Old Apr 11, 2001 | 10:38 AM
Car: 1985 Trans Am
Thanks, I got it. Anyone know what has to be done as far as modifications if I want to go to a full aluminum roller rocker?? Roller tips don't mean much to me, I just want the strength of a full bodied rocker instead of the POS stamped steel stock ones.
Old Apr 11, 2001 | 01:25 PM
Car: 1985 Trans Am
Also, am I looking for 3/8" or 7/16" roller rockers? I found these on E-bay, should they work?
http://cgi.ebay.com/aw-cgi/eBayISAPI...item=577593459
Old Apr 11, 2001 | 02:52 PM
Guest
Guest
Posts: n/a
You will need 3/8" if its stock otherwise. It should be a bolt in unless you run into pushrod slot problems, but I dont think you will.
Old Apr 11, 2001 | 03:03 PM
Car: 1985 Trans Am
Thanks Max, what about this self aligning/non-self aligning stuff?? When I look at the pushrod slot it has very little side to side room but there's plenty of room on the top & bottom. Do I have guideplates?
Old Apr 11, 2001 | 03:21 PM
Guest
Guest
Posts: n/a
No, you dont have guideplates. The self aligning rockers were used on 87 or 88 up centerbolt heads, so theres no worries there. That slot in the head is what guides the pushrod on your car and lots of others. Later ones had a large hole and the self aligning rockers. You will want the non self aligning ones.
Old Apr 12, 2001 | 06:49 AM
Car: 1985 Trans Am
Thanks a lot Max... you've been a great help. I just won those rockers too, so I should have them pretty soon. Thanks again.
Jorlain
Oct 8, 2015 01:57 AM
angel2794
Sep 8, 2015 06:22 PM
Vassago
Convertibles
Sep 4, 2015 09:37 PM
Formula_88AE
Sep 3, 2015 01:47 PM
masonta
Sep 1, 2015 06:40 PM
