installing pistons
Old Jul 6, 2004 | 02:11 PM
25thanniversary's Avatar
Car: 92 rs
Engine: 305tbi
Transmission: 4l60e
installing pistons
i'm having trouble getting my pistons back in i installed new rings and this is my first time putting pistons in is there any trick do i need to line the opening of all the rings up or somehthing or do i just compress them and put em in?
Old Jul 6, 2004 | 02:15 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
You DON'T line up all the rings. Read the instructions that came with them, they will tell you where to put the end gaps.
You need a tool called, appropriately enough, a "ring compressor".
http://www.sears.com/sr/javasr/produ...id=00904716000 for example
Old Jul 6, 2004 | 02:18 PM
Car: 92 rs
Engine: 305tbi
Transmission: 4l60e
obvisoly i'm using a ring compressior but i still cant get it to work i thought that u just had to put the ring compressor around compress the rings and tap the piston into the bore
Old Jul 6, 2004 | 02:26 PM
ede's Avatar
ede
that's all i ever done, compress the rings and tap the pistons in the hole. maybe arrange the end gaps in some mannor.
Old Jul 6, 2004 | 04:50 PM
blacksheep-1's Avatar
Car: 83 Z28
Engine: vortec 305 for now
Transmission: 5 speed
DO NOT line them up and DO NOT put them on the thrust faces of the piston either.
What kind of a compressor do you have?, There's the clamp kind that goes around and you squeeze it like a pair of pliars. There's the kind that clamps around and then you tighten an allen, then there's the really trick kind that's just a taperred hole that matches the bore size. There are probably others.
When you get the piston gaps where they need to be (a lot of theories here, do what the ring MFG says if you're not sure) Clean the heck out of the bore, oil both the bore and the ring compressor, line the piston/rod assembly up, put some tubing or something on the rod bolts so you can guide them and won't ding the crank, Put the compressed P/R assembly on the top of the bore, line it up and tap (sometimes a large tap) it in. I use a plastic hammer, some guys use the wooden hammer handle, whatever works for them. If you feel something weird STOP, pull it all out and look it over.
Old Jul 6, 2004 | 05:16 PM
z_power's Avatar
Car: '89 GTA
Engine: a bunch of pieces
Transmission: still there - very stockish TH700
This is the key, I think...
Old Jul 6, 2004 | 05:20 PM
Car: 92 rs
Engine: 305tbi
Transmission: 4l60e
i have the ring compression that goes around the entire piston and you use an allen key to tighten i have never set the ring gap could someone please explain it to me i have 305 out of a 92 camaro
Old Jul 6, 2004 | 06:54 PM
Auggie's Avatar
Car: 1984 Z28 Camaro
Engine: H.O. 355 NOS
You may have .005" over rings. Remove all of the rings from one of your pistons. Holding one of the compression rings vertical slide it into the bore for about an inch then rotate the ring down into the bore. Turn the piston upside down and slide it into the bore to square the ring with the cyl. wall and using a feeler gauge measure the ring end gap. If the ring will not go into the bore very carefully file the ends until you get the right gap. Use .004" for every inch of bore as a general rule of thumb. .004 x 4.0 = .016"
Auggie
Frozer!!!
Jan 19, 2024 04:55 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
theurge
Aug 21, 2015 12:46 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
