IAC Pic
Old Jul 8, 2004 | 01:51 PM
89IROCCVRT's Avatar
Car: '81 Camaro (Modded), '89 IROC cvrt (Stock), '00 GMC Jimmy
Engine: Modded 350 in '81, 305 TPI in '89 IROC, V6 Vortech in GMC
Transmission: T-350 in '81, 700-R4 in IROC
IAC Pic
I need a picture or description of where the Idle Air Control is. Sorry if its a newb question but I'm not exactly a certified mechanic so any help would be greatly appreciated...and the quicker the better, thanks!
i need to know what to disconnect in order to set the idle....it says to disconnect it, well, what do i disconnect? so i need a pic to see or someone to explain to me, thanks
Old Jul 8, 2004 | 02:09 PM
pecha's Avatar
Car: 98 T/A
Engine: ls1
look in here
especially on Vader's post
Old Jul 8, 2004 | 02:19 PM
89IROCCVRT's Avatar
i need to know what the electrical connector is tho....it says to disconnect the electrical connector to the IAC...well, what the hell is the electrical connector?? theres tons of wires by it and the TPS so i need to know which one it is
Old Jul 8, 2004 | 02:41 PM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
If you look on the passenger side of the throttle body, you will see the IAC sensor sticking out of the bottom (of the throttle body). I don't have a camera with me, but the URL below has an illustration...
http://fieros.westcoastfiero.com/Tec...Tech012002.htm
Hope this helps.
Best of luck.
Old Jul 8, 2004 | 02:46 PM
89IROCCVRT's Avatar
oh so i disconnect those wires that go to that IAC stepper motor or whatever its called...right below the TPS..?
Old Jul 8, 2004 | 03:24 PM
I'm not firmiliar with how to set the idle...
but the IAC is below the TPS sensor toward the front of the throttle body.
Old Jul 8, 2004 | 04:12 PM
Dr.NickRiviera's Avatar
Car: 1987 Trans Am
Engine: tree-fiddy
it should be a square-ish connector with 4 prongs, and has a green rubber lip. It is the only wire's that go to the bottom of the TB.
Old Jul 8, 2004 | 04:40 PM
89IROCCVRT's Avatar
yeah found it, i got her idling at approx 500 in park and in drive, i think i need a new tps sensor cuz i tried to adjust it and it was reading really high/nothing when moving it
92firebirdguy
Sep 1, 2016 07:53 AM
earlpote
Sep 12, 2015 11:55 AM
pacoelrapido
Sep 11, 2015 02:41 PM
greenyone
Sep 8, 2015 08:41 PM
greenyone
Sep 2, 2015 03:39 PM
