car dying?
car dying?
I have a 1990 camaro RS 3.1L V6 . when I start the car in the morning the car revs high and then shuts off, I either have to keep turning it on and off or press the gas. what could be my problem??
When was the last time you checked/adjusted/cleaned the IAC and TPS? (There's a tech article on it.)
89 iroc-z 305 tbi
k&n filtercharger, open element air filter. nuffin' else
89 iroc-z 305 tbi
Im not sure but I think the car ides very high (right on the number 1). and also the TPS is the self adjustable type so there is no way to adjust it(it has a plug).
I cleaned the IAC but I havent adjusted it.
is this the posible source of the problem?
I had a similar problem and I was told to check that...
The TPS should be able to be adjusted, you unscrew it and rotate it up and down a bit.
The symptoms for my car included: Searching for idle, high idle, reving up really high when starting then dying several times, dying when coming to a stop randomly.. few other weird ones. Haven't really had any of those problems since.
89 iroc-z 305 tbi
89 iroc-z 305 tbi
Does TBI's have IAC's? Sounds like an IAC that has carbon build up. If it does have one just pull it out clean with carb cleaner and the passageways. Try to get rid of all that carbon then put a drop of oil on the worm gear and reinstall.
'87 Trans Am:
(Engine)
305 TPI
180 Degree Thermostat
JET Fan Switch
TB Bypass
Accel 300+ 8.8 Racing Wires
Accel Super Coil
Bosch Platinium Plugs
Custom Ram Air with K&N
Removed Emissions Equipment & Cat.
(Stereo)
Full Kenwood Excelon System
'87 Trans Am:
(Engine)
305 TPI
JET Fan Switch
TB Bypass
Accel Super Coil
(Stereo)
db057
Aug 11, 2015 10:11 PM
