Did cruise control come with 85-92 manual camaros
Old Apr 16, 2001 | 03:44 PM
vortech305's Avatar
I have sort of a delema. I have an 88' 305 TPI motor w/ an 89' engine harness and 89'cruise control harness. Im insalling an 85'z28 t-5 in the 88' TPI and was wondering if its possible to install the 89 cruise control on the 85' T-5. Will the 89' engine harness be compatable with the 85' t-5. Did manual trannys come with cruise control.
92' camaro
New 305 block TPI conversion, Flat top pistons,Bore over .30 Forged parts all around,Edelbrock intake,ported plennum,ported corvette alluminum heads, accel cam,52mm throttle bodie, SLP runners Home aid cold air induction, Air foil,ford SVO 19lb injectors,fuel regulator,cloys timing chain, comp alluminum roller rocker arms and pushrods MSD 8.5 mm wires, bosch plattinum plugs, hypertech cap & rotor and coil, Edelbrock TES headers, free flowing catalytic converter and a 3 inch force II flowmaster exhaust system, and a 3 inch cutout,Zoom multi friction clutch, T-5 tranny,billenstien shocks&struts.
Soon to come!!!
Procharger system 12lbs o boost.
New paint job(hawaiin orchid purple)Cast alluminum ZR1 rims w/ 275 tires.
Favorite quote: "where ever u go, there u are"
Other car;
1971 plymouth Duster
Mods:340,edelbrock victor jr. intake, 650 4 barrel holley, heddman headers,40 series dual flowmasters, cold air intake,4:10 gears, just got a new paint job and cragar rims with 315 tires in the back.
:Yeah its not a chevy but damn how many 71' dusters have u seen in the streets.
Old Apr 16, 2001 | 05:03 PM
Killer-Z's Avatar
yup, i've got it on my 91z
Old Apr 16, 2001 | 05:19 PM
IROCketZ28's Avatar
You could get cruise on the 5-speed trannys. My '87 IROC has cruise, although non-functional (one of these days I'll take the time to figure out why). I am not sure about the compatability of an 89 harness to an 85 T-5, but I'm sure it can be done.
By the way, if anybody feels like posting any hints to troubleshoot a non-working cruise control, I might get started on the project soon! Thanks!
'87 IROC Z28
TPI 305
5-speed w/ Centerforce clutch
3 1/2" exhaust w/ Flowmaster
Clarion, Kenwood, Eclipse, Polk, MTX, Autotek 800 watt stereo system
Grant wheel
Otherwise stock, & good for a 14.68 at DeSoto Dragstrip
More to come soon...
Shooting for high 13's with bolt-on's
Old Apr 16, 2001 | 05:35 PM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
Yes...I have it on mine
92 Camaro RS LO3, 5-spd, T-tops
Performance:
SLP 1 3/4" Headers (Coated by Paul Barry Motorsports), Flowmaster Catback Exhaust, Fastchip Performance PROM, Centerforce Dual Friction Clutch, Xact 8mm wires, Open Air Element w/K&N Filter, Z28 Grille w/aftmkt fog lamps
Electronics:
Alpine 8030 Alarm System, Valentine One Radar Detector (How did I ever drive without one?), Pioneer DEH 7450 Head Unit w/6-pack CD changer, Pioneer DEQ 7600 Sound Processor, 2 Kenwood KAC-846 Amps powering 2 12" Pro Red subs, 2 Pioneer 6x9 and 2 MTX 4x6 speakers.
NEXT UP: TBI mods, Edelbrock performer intake
Old Apr 16, 2001 | 05:45 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Mine has it (83 Z28 HO 5-spd.), works fine.
Can't answer the model-year compatibility question though. Sorry.
ICON Motorsports
Old Apr 17, 2001 | 08:38 AM
Steve89GTA's Avatar
Got it! (and it works)
89 GTA G92
305 TPI WC 5spd w/3.45
Accel Cap & 8mm Taylor's
Custom 4" Cold Air Induction
Jet Airfoil
K&N Airfilter
160 deg stat/fan switch TB Bypass - Steel Rad
Cat back 3" Exhaust w/Terminator Muff.
HiGh FlOw Dynomax Cat
Spohn LCA's - KYB GR-2's
Moroso Crank Bolt and roller pilot bearing.
Autometer Vac+Oil Temp
Old Apr 17, 2001 | 08:47 AM
vortech305's Avatar
thanks guys i just have one more question. Since i have a 92' camaro, in the RPM odometer is a shift light(which light up to upshift w/ manual equiped vehicles)since my car came equiped with the v-6 700r4 does the engine harness from an 89' 305 TPI which had a t-5 come equipped with sensor to make the shift like operational. Does it matter if the t-5 is from 85'.
92' camaro
Soon to come!!!
Other car;
Old Apr 17, 2001 | 10:34 AM
raging86's Avatar
i think you will need a different printed circuit in the back of the dash cluster and a bulb and socket. you will also need a different EPROM chip, you can't use the auto chip in a manual application.
86 IROCZ
T-Tops
700R4
305 TPI
3.23 gears
shift kit, manual TC switch, manual fan switch, flowmaster exhaust with edelbrock TES headers& hollow cat, gutted MAF.
Old Apr 17, 2001 | 11:04 AM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
-No you can't use that cruise control harness as is. You need to convert your tranny to an electric speedo output, your 85 tranny will have a cable output. You'll need to do this one way or another anyway to make it work with your 92 dash.
-As to the 'shift' light, you shouldn't need to actually swap anything, you should just need to put a bulb/holder in the hole in the appropriate hole. My car is an A4, but IIRC when i had it out it looked like all the wiring for the shift bulb is already in the printed circuit. This light is controlled by the ECM, and uses the same driver as the TCC solenoid for A4 cars.
-As someone pointed out, you really should get a chip for a manual tranny car. If you don't one thing is for sure, the shift light will work really funny as it will light whenever the ECM commands for TCC lock-up.
...ed
Ed Maher - Moderator @ The Carb Board
92 Z28 Convertible - Quasar blue / Tan top
LB9 4L60 GU2 G80 - stock, soon to be sleeper
-=ICON Motorsports=-
- Definitely prototypes, high powered mutants of some kind. Too weird to live, too cool to die
Old Apr 17, 2001 | 11:24 AM
Pukka's Avatar
Why bother trying to get the shift light to work? If you drive it hard at the least, the light will stay on...especially annoying at night. You will probably burn it out in no time. I kinda miss mine, but I'm not in a rush to replace the bulb. Just my .02
Old Apr 17, 2001 | 01:42 PM
vortech305's Avatar
the 88' block which was worked, i bought it from a junked firebird with the 305 TPI,and had a t-5 in it. The motor, engine harness, and computer was included so i do have a computer for the manual.
eightsixseven
Dec 16, 2024 01:50 PM
Street Lethal
Aug 13, 2015 08:28 PM
stalkier
Aug 13, 2015 12:59 PM
Street Lethal
Aug 12, 2015 11:33 AM
Bull86
Aug 10, 2015 05:43 PM
