Attn: Vader and ede. Tentioner teardown update>>>
Old Apr 17, 2001 | 12:28 AM
Jester's Avatar
I took my tentioner apart, reversed it, and got it backtogether. My belt routing problems are over
The design of the tentioner seemed to be very much different than you described Vader. There was no locknut, the assembly was held in place by a retaining clip right on the front only, that was only press fit. The assembly only had about a half turn of tention on it was well, with a fairly thick spring. I put it in a vice, and popped off that clip off with a screw driver. It unwound a half turn, maybe 3/4 I'm not sure. The clip can be rotated in 90 degree incrememts as well. I then basically preloaded the spring the other way, and replaced that clip rotated so it retained it in that position, and could be pulled further to supply tention to the belt. The clip went back on with a c clamp and a hammer fairly easily. I drilled a new hole in the bracket for the locating dowel, almost 180 degrees off from the original, and bolted it up.
Here is a pic of the finished product, with a measuring tape laid in place of the belt for a visual. note the tab on the side of the pin, showing how far it can rotate in which direction.
EDIT: By the way, while I have you here, will the water pump stil spin the right way (original serpentine belt pump), or not? I've completely lost track...
"American made baby. 100% American iron. The muscle among the masses. My hero. Yep, you can take your ergonomically designed, space age, computer controlled, 4 door, cup holding map lighted split double wishbone split fold down retractable cargo covered moon roof piece of transportation and keep it. For I have felt the thunder. And I know the difference!"
JSP Motorsports
ICON Motorsports
[This message has been edited by Jester (edited April 16, 2001).]
Old Apr 17, 2001 | 12:53 AM
ZBRA's Avatar
Car: 1972 Corvette
It looks like the pump will be turning the correct way. If it is spinning the opposite direction of the crank, then it is correct. It also seems like if it is still running off of the smooth side of the belt, then it will be reversed, and therefore correct.
----So if she weighs the same as a duck, then she is obviously made of wood, and therefore........???
'91 Z28 Blue/Silver ZZ4/ZF6
335.9 rwhp 374.9 rwtorque
--==ICON Motorsports==--
Old Apr 17, 2001 | 12:58 AM
Jester's Avatar
She's a witch!! heheh I love that movie Monty Python is the best.
Thanks ZBRA.
JSP Motorsports
ICON Motorsports
Old Apr 17, 2001 | 04:57 PM
Jester's Avatar
BTT
Old Apr 17, 2001 | 05:22 PM
ede's Avatar
ede
damn jester i'm impressed. no 4x4 blocks of wood or welding rejuired and it seems you have it figured out. i still think you're lucky you never put your eye out.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Apr 17, 2001 | 06:14 PM
D_Amlee's Avatar
Car: 89 IROC
Engine: Yes
Transmission: That, too.
Ok, I'm looking hard at the photograph trying to figure out how much wrap you will end up with around the crank pulley. The stock setup has over 180 degrees of wrap around the crank, ensuring that the belt doesn't slip and all the accessories get enough belt traction. Is your current plan to have the belt run from the bottom of the PS pump pulley down under the crank, then up the left side of the motor to the Alt pulley? If that is what you have in mind, will you have enough contact with the crank pulley to avoid belt slippage?
89 IROC with lots o' stuff
-=ICON Motorsports=-
Old Apr 17, 2001 | 06:25 PM
Jester's Avatar
D..I've had that same thought...and I'm not really sure. If it slips...I'll just have me a custom underdrive belt system
Old Apr 17, 2001 | 06:27 PM
Jester's Avatar
Alth..if it does slip I bet I could rout it a different way...up over the water pump first, then to the alternator...that should work....
Old Apr 17, 2001 | 07:23 PM
Vader's Avatar
Jester,
"Very small rocks?"
Your tensioner looks/sounds a lot different than the one I disassembled. It was from an '88 truck. I'm glad it worked out for you. They aren't that complicated, and even rocket science isn't rocket science any more.
Maybe this wrap would give you the drive you'll need:
Later,
Vader
"What a Day..."
Adobe Acrobat Reader
Old Apr 17, 2001 | 07:30 PM
Jester's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Jester:
Alth..if it does slip I bet I could rout it a different way...up over the water pump first, then to the alternator...that should work....</font>
Yeah Vader, thanks thats exactly what I was talking about here. Thanks for drawing it up for me
JSP Motorsports
ICON Motorsports
Old Apr 17, 2001 | 08:25 PM
Rob P's Avatar
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
Youz guyz are pretty smart, and creative.
(me puts the reverse tensioner trick into the memory bank for possible future use)
Rob P
89RSconvtZZ4TPI
Edelbrock Hi-Flow Intake
SLP Dual Cold Air Intake
1 5/8" Headers
Semi-Siamesed Runners
MSD6AL/relocated MAT/ AdjFPR/IROC frnt@rear swaybar/wonderbar/steeringbox/alum drvshaft/ Alston SFC/3:23posi disc rear/MAC LCA/H.Adams Panhard Rod/KYB struts/ shocks/
92Z28convt5spd
71Impala convt 402BB
BETTER DRIVING THRU SUPERIOR HORSEPOWER!
Old Apr 17, 2001 | 08:27 PM
JP84Z430HP's Avatar
Car: 84 Z28
Engine: 355 (fastburn heads, LT4 HOT cam)
Axle/Gears: 9-bolt, 3.27
Is that gonna be enough for the alternator? Probably will, but if you run it around the alt, then w/p, then crank, then p/s pump, you should get nearly half the diameter of all the pulleys covered. I didn't draw it up like Vader did though, so I'm not sure if there will be any interference. Just another thought to ponder for you!
Working on:
'84 Z28 LG4 305 with 200,000 original miles!
Added dual elec fans.
145 MPH IROC Speedo
Building 430 HP 350 (ZZ430)
using primarily GMPP parts.
Short block sitting on a stand. (Man, those Fast-Burn heads sitting on it look good!)
Starting to look like the Kicker poster child!
ASE Certified Master Tech
FormulaEngland
European Region
38
Jul 17, 2016 07:33 AM
2012sergen11
Oct 13, 2015 07:38 PM
mattcanty
Oct 12, 2015 11:08 AM
Aaronv808
Members Firebirds
Sep 30, 2015 12:55 PM
