i cant take this anymore
Old Jul 23, 2004 | 10:44 AM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
Transmission: TKO-600 5 speed
Axle/Gears: 3.73 10 bolt
Well im hoping that my plethora of problems is being caused by my alternator. So this morning i go to take the alternator off and take it to have it checked out. Well wouldnt ya know it the bottom bolt on the alternator is completly stripped it was a torques bolt at one point. I have no idea how im going to get that out
Old Jul 23, 2004 | 10:45 AM
Kaukasion's Avatar
Car: 84 z28
Engine: older 350, details unknown
Transmission: th350
Axle/Gears: factory limited slip
if you gotta drill get a set of easy outs
it takes a while but you can get it out
Old Jul 23, 2004 | 10:50 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
A good pair of visegrips works well.
Old Jul 23, 2004 | 10:53 AM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
to the first reply, there is no way there is going to be enough space to drill it out unless i pull out the radiator and i dont even want to think about that.
And as far as vice grips i tried, but its a torques bolt so the head of it is like half of a sphere, so they wont grab onto it, and i doubt you could get it to budge with those even if you did get em locked on, which you cant.
Old Jul 23, 2004 | 10:55 AM
Kaukasion's Avatar
Car: 84 z28
Transmission: th350
take to someone with a welder
find an old socket that you dont need anymore
get it welded on to the head of the bolt and turn her out then go buy a new bolt
Old Jul 23, 2004 | 10:57 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Well, another alternative is to take a file and file two sides flat and put an adjustable wrench on it. Just a thought!!!!!!
Old Jul 23, 2004 | 10:59 AM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
Ya but the reason im trying to take my alt off is because my car is completly fuxored so my car wont even make it down the street.
And the file idea at this point seems like my best option
Old Jul 23, 2004 | 11:03 AM
Kaukasion's Avatar
Car: 84 z28
Transmission: th350
yep sounds like you best bet but its gonna take you a while
good luck with ur car
Old Jul 23, 2004 | 03:02 PM
Lonestar's Avatar
Car: 1985 Firebird
Engine: 327
Transmission: TH350
Dremel
Bubbajones_ya
Jul 6, 2024 08:32 PM
RedLeader289
May 28, 2019 01:47 PM
Zell1luk
Sep 29, 2015 10:36 AM
Mdenz3
Sep 17, 2015 08:36 AM
Ikes 91Z
LSX and LTX Parts
Sep 13, 2015 09:03 AM
