My baby won't start
Old Jul 23, 2004 | 09:43 PM
Jacker550's Avatar
Car: 86 Camaro IROC-Z28
Engine: SB 350
My baby won't start
Ok....so i just dropped a rebuilt 350 motor into my 86 IROC. It was turning over but not starting.....so i went to adjust the timing on the distributor and when i went to start it again...nothing. I have checked all of my connections throughout the whole ignition and cant find anything.....can anyone help me?
Mike
Old Jul 23, 2004 | 10:28 PM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
Fuel/Air/Spark
Air is probably not an issure. Do you have fuel getting to the engine? Is the timing correct?
Old Jul 24, 2004 | 10:08 AM
Jacker550's Avatar
Engine: SB 350
Yes...fuel is getting to it....it just isnt turning over
Old Jul 24, 2004 | 10:29 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Is this a freshly built engine? Not some crate? Is the timing set lined up dot to dot? If yes, was the distributor installed pointing to #6, not #1?
Make sure youre not 180° out on the dizzy.
Old Jul 24, 2004 | 10:31 AM
dankhound's Avatar
Car: 91 RS
Make sure your getting power to the small terminal with the key in the crank position. Do you even have 12v to the big terminal. Easy way to check that without a meter is to use a screwdriver and connect the two terminals.
Old Jul 24, 2004 | 06:43 PM
greenfrogg's Avatar
Car: 89 FORMULA355 80 TURBO TA 355
Engine: 355 tuneport 355 chev CARB
Transmission: 700 350
if itis a tpi check the distributor wire and the wire under the back of the tune port as they plug into each other .i learned this the long time wait way good luck
Old Jul 24, 2004 | 06:56 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Originally posted by greenfrogg
if it is a tpi check the distributor wire and the wire under the back of the tune port as they plug into each other .i learned this the long time wait way good luck
Are you by any chance referring to the wires going to the ignition module from the igntion coil and the ECM.
P.S. don't get confused and connect the harness for the MAT into the ignition module instead of the ignition coil harness. The connectors are the same.
Old Jul 24, 2004 | 10:20 PM
greenfrogg's Avatar
mybaby
yep thats the one it took me amonth to figure that out the only way i did was by talking to preevious owner
Old Jul 25, 2004 | 12:32 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
First, as said, make sure you're getting fuel/air/spark. Next, check to be sure you're getting spark at the right moment- it's very easy to be 180 off, or even just out of sync. Next, if your car still won't turn over, be sure your valves are properly adjusted. That was my problem. Other than that, you're set. All it takes for a car to start is fuel, air, spark, and compression. Many people forget about compression.
Derick15
Sep 17, 2016 05:28 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
EFR2000
Aug 18, 2015 08:54 PM
