Ignition module ?
Old Jul 27, 2004 | 11:58 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Ignition module ?
When I disconnect the timing connector and rev the engine should the timing remain constant or move?
I have checked several cars and one will retard about 6-8 degrees and another one will advance 6-8 degrees, what gives, which one is right?
Anybody have any ideas?
Old Jul 27, 2004 | 12:03 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: Ignition module ?
With the EST dissconnected the timing will move when you increase the rpm's. That is why you need to set the timing with the car at an idle.
Old Jul 27, 2004 | 12:17 PM
Dyno Don's Avatar
Re: Re: Ignition module ?
Right....so...should it move up or down when you rev it?
Old Jul 27, 2004 | 12:23 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Re: Re: Re: Ignition module ?
It should advance.
Old Jul 27, 2004 | 01:26 PM
88305tpiT/A's Avatar
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
I am confused...
I thought that the computer contained all advance information and relayed ALL timing movement to the dissy via the EST wire. Every time I disconnect it I get no advance with rpm.
Old Jul 27, 2004 | 01:28 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Originally posted by 88305tpiT/A
I am confused...
It does but it still will advance without the computer to keep the car running and to prevent damage. I am not sure how it does it though. Someone will have to school me on the finite functioning of the HEI.
Old Jul 27, 2004 | 01:30 PM
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
oh that could be... maybe like the module has a backup mode when no EST signal is present?
Maybe I just have S*&$%y modules then. I have had many problems with them.
Try posting this on the DIY forum Don. You may get someone to speak up about it.
Old Jul 27, 2004 | 01:49 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Yes, it is a backup mode built into the ignition module. With the EST connector open the timing should hold steady. As the RPMs increase there should be a sudden advance in timing in the 1,600 to 1,800 RPM range (sometimes as late at 2,000 RPM which is an upper limit of a borderline module).
The distributor that is decreasing in timing as the RPM goes up has something wrong with it.
RBob.
Old Jul 27, 2004 | 01:55 PM
Dyno Don's Avatar
Thanks, RBob
That clears it up.
Old Jul 27, 2004 | 02:06 PM
Jon92TA's Avatar
Car: 92 Trans Am - Sold
I was just wondering about this myself. When I got the car smogged a month ago the Tech said my timing was at 9*. I was getting some pinging so I went to set it back to 6*, When I checked my base timing, est disconnected, it somehow had increased to about 14*. After setting it back to 6*, est disconnected, I thought I might have another problem seeing it jump to about 12* at 1800 rpm. So this is normal for a 92 305TPI?
InfernalVortex
Apr 20, 2021 11:31 AM
RedLeader289
May 28, 2019 01:47 PM
Gunner242
Dec 25, 2015 04:49 PM
dusterbd
Sep 29, 2015 08:40 AM
tattmann
Sep 27, 2015 05:20 PM
