2.8->3.4 swap gone awry.... please help....
Old Apr 23, 2001 | 01:29 PM
87CamaroLT's Avatar
Hi guys. I normally reside at the V-6 board, but some of them sent me over here with my questions (guess they got tired of me ). This might get a little long, so grab a bee-- um... soda, and relax.
I just did a 2.8->3.4 swap, in my '87 Camaro. When I first completed it, buttoned everything up, filled the motor with all neccesary fluids and such, it actually ran! However... It didn't run right. It kinda bogged down when I "snapped" on the throttle. In order for it to rev up, I'd have to push the gas halfway (or more), and hold it, and it would eventually get there. So, I set the timing, changed the spark plugs, and checked for vaccum leaks. No good. Still did it. I did notice that the car smoked when just sitting there, revved up to about 3500. So, I looked under the car after it started smoking, and the catalytic converter was glowing red hot.
Now, this lead me to believe that it was clogged up. So, I go out there with a big ol' sledgehammer, grinder, and a prybar and cut it off. Now it won't start! I'm only thinking that it could be a couple things. I'm really doubting that it could be because of low backpressure. But, again, I'm not sure.
Let me give you a little history on the car, so you have a better idea of this:
-Blew up the 2.8 in June '00
-Got the 3.4 with 50K mi. on it in Jan. '01
-Finally got it in, and started for the first time in late March '01
-First time out, a big wire loom melted to the pass. side exhaust manifold, melted the fuel pump wire, grounded it out, and popped the fuse... (had to tow it home....)
So, the car actually sat, with a tank full of gas for, about 9-10 months. Maybe the fuel pump, filter, or lines are clogged? I'm not sure...
So, what I'm really asking for is some ideas on what you guys think is going on. I'm stuck, and like I said, I've got my ideas, and I just want to hear yours (unless you've got the answer... then I want that )
Thanks for any help, I really appreciate it...
-Steve-
--'87 Camaro LT --
Successful 2.8->3.4 swap...
Old Apr 23, 2001 | 02:26 PM
ColinOpseth's Avatar
Car: 1987 Camaro IROC-Z
Engine: 305TPI
is your knock sensor hooked up? my car did that when the knock sensor came unplugged
Webmaster: www.IROC-Z.org
Old Apr 23, 2001 | 02:54 PM
Bort62's Avatar
I would be willing to Wager you are Running Rich.
That would explain the Glowing Cat, the Smoking exhuast, and Sorta explain the bog.
As far as teh car Not starting w/o the cat< that has to be because you srewed up something else in the process of removing it with the delicate tools you describe.
there is No way that the Cat being present or non present will effect the car's trying to start.
Hope that Helps, I don't know enough about the 6's iduction to get any more specific Than that.
60 Ranchero - Project ( Money Hole )
85 Sport Coupe LG4 - Daily Driver
Just another Hot Rod kid, or thats what they all tell me.
Livin' the Stereotype
Old Apr 23, 2001 | 03:04 PM
Engine: 305TPI
his car sounds exactly like mine did when my knock sensor unplugged and the car went into limp-home mode... smoking cat, stinky smell, running very rich, timing retarded..
Old Apr 23, 2001 | 07:00 PM
84IROC's Avatar
the timing is definitely way retarded, this will explain the exhaust manifolds/cat (unburned fuel in the exhaust), hard to start and when it did run; the lack of throttle response can be attributed to this.......
'84Z28/'92 305TPI
'92 complete rear suspension/PBR disc/Posi/3:42
Light weight 34.5mm stabilizer bar in front ($10 from wrecking yard)/
"wonder Bar" ($5 from wrecking yard)
23mm sta. bar in rear
Rear RS Springs (slightly softer than my Z28)
comp cam, flowmaster
TB coolantbypass/shutoff valve to heater core
powersteering cooler lines (liberated from another wrecked car of course)
MAT relocated
Ram-Air(home-made) gutted air-box
IROC ground effects/wheels GY245/50's
700R4 superior shift kit/ corvette servo(excellent shift kit btw)
home-made strut tower brace (cost $6)
Rebuilt engine and transplanted it myself.
Love this engine!
freshly painted OCT. 2000 Teal with two white stripes on the hood and deck lid
LOW performance people should drive low performance vehicles!
Old Apr 23, 2001 | 07:54 PM
ede's Avatar
ede
yeah i'll go with the timing is off. recheck it and see what happens
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Apr 23, 2001 | 08:27 PM
87CamaroLT's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Bort62:
</font>
Heh... well, I was careful with the "delicate tools".... The car only shifted on the jackstands once! (And I got the hell away from it when it did, too )
Now... as for the knock sensor. I'm gonna go check the Chilton's and Haynes manuals, but, can anyone give me a idea of where it's at? I've been over the sensors a bunch of times, just checking to make sure everything's hooked up, and it is (as far as I can see)... so, maybe it's hidden somewhere that I didn't see... thanks again guys....
-Steve-
--'87 Camaro LT --
Successful 2.8-&gt;3.4 swap...
Old Apr 23, 2001 | 09:32 PM
JP84Z430HP's Avatar
Car: 84 Z28
Engine: 355 (fastburn heads, LT4 HOT cam)
Axle/Gears: 9-bolt, 3.27
The knock sensor should not be preventing the engine from starting. It could be what caused the cat to burn itself up, if you were experiencing detonation causing the cat to work harder to burn the excess fuel.
It soulds like you have come across another problem. I'd start with the basics, fuel pressure, spark, compression (maybe the engine get too hot and blew a head gasket, no, I'm not wishing that on you!) and check to see if the injectors are getting their signal. I can't think of anything else right off, but maybe after I get some sleep, and maybeget some more feedbackon things you've found.
Good Luck!
Working on:
'84 Z28 LG4 305 with 200,000 original miles!
Added dual elec fans.
145 MPH IROC Speedo
Building 430 HP 350 (ZZ430)
using primarily GMPP parts.
Short block sitting on a stand. (Man, those Fast-Burn heads sitting on it look good!)
Starting to look like the Kicker poster child!
ASE Certified Master Tech
E Rod
Aug 28, 2015 05:17 AM
theshackle
Aug 22, 2015 06:52 PM
Hello, Michael
Aug 20, 2015 03:19 PM
355sbcTPI
Aug 19, 2015 04:38 PM
92projectcamaro
Aug 6, 2015 01:20 PM
