what heads/cam/intake for ~$1500
Well, with roughly 20,000 miles on the rebuilt motor, I popped a timing chain.
Its my own ****ing fault and I deserve it for cheaping out on a Vatozone "double roller" sub $40 chain.
Anyways, I don't want to go into change it without correcting the weak points in my setup that bug the **** out of me.
Problem is, I really only have about $1500 to spend, MAX.
In a perfect world, that would mean vortec heads, a stealthram, and something like a hotcam.
However, this isn't a perfect world, and you can't bolt a stealthram up to vortec heads. Plus, there isn't any other head even close to their performance for the price.
I really need to replace the heads, first because they have 180k on them with nothing but new springs, seals, and a ghetto valve lap, and two, because its a fair bet I messed up a valve with the timing chain went.
Second, I really need to ditch the TPI setup. It ****ing sucks.
This is currently on a 355 with forged flattops, around 9.8:1 compression with shim headgaskets, and a stout bottom end. Currently it has 1 5/8" headers, and full exhaust with a cutout before the cats, ported plenum and ported SLP runners, 1.6 ratio roller rockers, 2400 stall and 3.73 gears.
Current cam is a production LT4 cam (NOT A HOTCAM)
I understand that at $1500 bucks, I'm gonna have to make a comprimise, and that sucks, but it is what it is. What do you guys suggest?
__________________
__________________
Car: 89 Camaro RS
Engine: 350 carbed now
Transmission: World Class T5
Axle/Gears: Peg Leg w/ 3.73's
Its gonna be tough to get a good set of heads, a nice roller cam, and a TPI intake for $1500. So heres what I suggest: Get a set of Edelbrocke Aluminum RPM heads about $1100, Lt4 hot cam about $350(maybe $150 used without lifters), and misc gaskets $100. So your basically at your limit there. Go ahead and get these parts and start saving for the intake. One problem your going to run into is tuning. however with this head./cam setup, a good high flow TPI setup, and a good tune youll easily have over 400hp at the fly wheel.Just my
I'd rather go AFRs, Trick FLow 23*, or Pro Lightnings over edlebrock.
And I really don't want to have to stick with a TPI manifold for any legnth of time.
Are there any heads for under $500 bucks that flow decently enough to get 325-375 hp on a stealth ram?
Car: '82 Z28
Engine: 350HO
Transmission: M4
why not buy a set of LT1 heads, they usually go for real cheap, have the reverse flow water ports plugged and welded. Buy a LT1 intake from www.lt1intake.com. and buy a stout roller cam.
many a people are running 12's with cammed bolt on LT1s.
its alot of work,but that would probably give you the most bang for your buck,
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
LT1 heads don't work on a Gen I block without modification to the coolant passages.
Car: 89 Camaro RS
Its realistic, and you can do it pretty cheap, but its a big PITA. You can get the heads used for $300 have the coolant passages welded shut for another $200(just a guess) and then get the Lt1 intake on that web sit for like $300, then the cam for another $350, plus misc stuff(gaskets, hoses, whatever) For like $150 or so. Your looking at a decent deal. And Lt1 heads flow almost aswell as vortec(ALMOST). But its a big PITA.Someone on this site did a step by step how-to on it.
Car: '82 Z28
Engine: 350HO
Transmission: M4
I believe it was TPI383 that did the swap(but i could be wrong) either way, do a search, you should find it. The thread is very long and has tons of pictures. good stuff.
And for the price of the LT1 heads/intake, i think it is the best fuel injected deal going under $1000.
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
There is no such thing as impossible. Just limited perception of that which is possible.
As for building your own heads, here is a quick and simple recipe for DIY aluminum heads: Go buy 100000 lbs of aluminum siding. Melt them down to a molten state. Put the liquid into a cardboard box and harden. Poke some holes with a toothpick and cover some areas with duck tape. Pop in the microwave overnight and viola, instant aluminum heads, fit for a box car derby.
Here's a semi-bright idea from myself: By a set of Darts or Pro Toplines or something, some bare castings for like $5-600. Buy a Comp Roller cam and what not. You can reuse the lifters and whatnot if you desire. Between the springs, retainers, locks and what not, that will set you back the rest of the way.
Just a thought. Nothing impossible.
Car: '82 Z28
Engine: 350HO
Transmission: M4
Here is the thread by tpi_roc detailing the swap.
https://www.thirdgen.org/techbb2/sho...hreadid=178262
It requires 4 pieces of aluminum, cut to size, have those welded up, then have the head surface decked.
Not that complicated. Any machinist with an IQ higher than his shoe size should be able to take care of the machine work easily. And it shouldn't cost you much.
Plenty of power, plenty cheap, which is what he is asking for.
Aftermarket heads + Aftermarket induction + Aftermarket roller cam probably = more than $1500
Car: 86 coupe
Engine: 383
Axle/Gears: 9 bolt 3.27 posi
toplne vortecs $460 bare, pbm stainless valves $112 racer price,comp 274xe $175 w lifters,comp 981-16 valve springs 59.99,pc valve seals $21.99,comp 10*retainers 59.99,comp 10*locks 26.99,arp 3/8"studs(ebay)$24.00 incl shipping,comp 1.52:1 roller tip rockers(ebay)$90 incl. shipping,edelbrock rpm airgap vortec manifold(ebay)$180 incl shipping,intake gaskets $26.00,head gaskets avg 60.00,arp standard series head bolts $49.99,arp stainless 12 pt vortec intake bolts $23.99,=$1592.94
ok well thats the way i did it,there are corners that can be cut for sure!but i didnt want to do that,in fact i kind of ran overkil most of the way.point is if you are a careful shopper,you can pull it off and use top notch parts that will last a long time!
btw the pbm valves for the vortec heads will match the valve seats of the topline #906 vortec replacement heads perfectly!lap em if u want.
oh yeah,good advice,priceless!
Eric
Eric
Car: 92 T/A VERT
Engine: LB9
Transmission: AUTO
Axle/Gears: 7.5 / 3.42's
AFR 180's for now, save money for the stealth ram and cam later. I'm with you and would'nt want to waste money on TPI parts (ie vortec base)
Eric
Eric
1. I'm not sure if I want to ditch EFI.
2. I'm not sure how your combo is going to run without a carb, the linkages I'd need, a low pressure fuel pump, and all the others stuff I'd need to get a carb conversion motor running.
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
eh, newsance, i was going to reply over at 3go, but i figured you would already go teh obvious route.
you're using a stealthram, thats a given.. so after bits and pieces for that swap (assuming nothing breaks or comes up) you spend about $650.
that leaves $850 for the heads. you're not a idiot, so you know you cant get any new assembled heads worth a damn for that. nevermind heads and a cam.
if i were you, i would find a nice set of assembled used heads.. Iron eagles, pro topline, or somthing similar. spend the money to get a valvejob done and if you do it yourself, possibly port them.
then spend $50 on a two piece timing chain cover.
3months from now, or whenever you get around to it, swap the cam for somthing decient. you wont have to pull the oil pan,and the stealthram isnt a bitch to take off like TPI. not too hard.
Car: 91 Camaro Vert
btw, before someone mentions my vortecs toward my 850 head combo
they dont work with the stealthram.
he doesnt want a LTR setup so the vortec base is out
and he doesnt want to spend the time buying a LT4 intake, modding it, only to find out that the internet rumor about it fitting the vortec heads is BS and noone has even done it yet.
even if you get vortec heads, the springs suck. and they have to be machined if you want more lift.
and even if you DID find assembled aftermarket heads that cheap, would YOU trust the quality of the components in your motor?
Ok, what about this...
1. Stealthram (duh)
2. A decent rebuilt stock casting with 64CC chambers, 2.02 1.60 valves. Something like fuelie or LT-1 castings.
3. A cam to match.
This is the only realistic option I see to getting it all done under the $1500 bucks that I have to spend.
I'm not looking to make incredible power numbers, the car runs just fine for me after the N20 is packed on. My biggest motivation is getting new heads because mine are worn, getting a new intake because TPI sucks.
Or perhaps rebuilding the B2L heads. I have heard that B2L heads really flow like **** before, then others say that they are decent for a stock head. What is reality.
If I wanted to get 350 hp out of a motor, would a stealth-ram, agressive cam, and B2L heads get me there?
Would other stock NON VORTEC castings get me there?
1. Stealthram (duh)
3. A cam to match.
Car: 91 Camaro Vert
realisticly? no.
in la-la-benchracing land? you would just get there.
without good porting, you arnt going to get that from any older stock heads. atleast not any that are cheap enough to save over a aftermarket head.
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
Originally posted by MrDude_1
btw, this is just your car getting pissed at you for buying a omni.
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
I'd look into the Pro Topline 906 Vortec heads they are much better then stock Vortecs and are setup for performance right out of the box. Supposedly they also fit both intake patterns, atleast thats what they say.
There are issues with me getting my credit card payment back, which is why I have not said much for legal reasons.
Car: 82 Z28
Transmission: TH350
Wait nevermind i just checked thier site again and it say Vortec style, so.... Sorry!
You could go with their 083 heads.
Or their Pro Torker heads.
http://www.protopline.com/racingironsbc.htm
Down at the bottom
Down at the bottom
Transmission: 4L80E/4L80E
Personally, I don't see:
1) Anything that disqualifies the stock heads - Port 'em, replace valves/guides as required, install good valve springs & seals, run 'em.
2) Any way this is going to all happen for $1500. Modifying/replacing TPI and doing cam and heads is just going to take more money than that.
Car: 92 T/A VERT
Engine: LB9
Transmission: AUTO
If you have the $1500 to spend right now, why don't you just get the best heads for your application right now? Port your stock tpi stuff, keep the same cam, tune/save money, then buy the stealth ram and while you swapping intakes... swap the cam?
Car: 91 Camaro Vert
side note for all heads that fit vortec AND "standard intakes"
the ports are still taller... so while any 23* intake will bolt on, only the big race intakes cover the ports.. i think they take a 1207 intake gasket..
in anycse, most intakes will not have enough metal around the edges to cover the larger ports... thats why everyone doesnt just drill out new bolt holes on vortec heads.
newsance:
sucks about that omni, but what do you expect when you run that much boost? plus it DID sound a lil shady that he was selling it after swapping motors...
i know you know TPI sucks, but i dont think you can replace it and do the heads/cam at the same time for under 1500.. if you do, you're comprmising somewhere...
you know you need to swap that cam, and you know you need heads rebuilt. you dont NEED to swap intakes now. and the real power from the motor is in the heads... in the long run, i think you're better off right now doing the heads and swapping cams.
used parts are cheaper, but you'll have to start looking for deals.
its not your daily driver, so you may just want to get some cheap castings and a $40 porting kit.. spend a couple hours a day for a week or two to port them out, then get a valve job and run em.
it wont be fast with the TPI still on it, but 3 months from now, you just have to swap intakes.
newsance:
sreZ28
Oct 22, 2015 08:21 AM
blackandblue02
Sep 10, 2015 08:19 PM
