best hp/et with vortec heads?
Old Aug 3, 2004 | 08:06 AM
SLEEPER 86's Avatar
Car: 86 coupe
Engine: 383
Axle/Gears: 9 bolt 3.27 posi
anyone making 450 hp or 11's with these?
Old Aug 3, 2004 | 02:21 PM
scottland's Avatar
Car: '82 Z28
Engine: 350HO
Transmission: M4
pony killer ran 11.9x i believe on vortecs + a XE274H
Old Aug 5, 2004 | 10:05 AM
GASGZLR's Avatar
Car: 1991 Camaro Z28 5.7 G92
Engine: L98 Tuned Port Injection
Transmission: TH700R4
Axle/Gears: 3.23 Posi G80
I just came back from the dyno yesterday and I made 407.7 hp and 480.1 tq at the rear wheels with stock Vortec heads that have not even been ported and with less than .500 lift and a 50 shot under the carb. It still has way more in it. My timing is falling off at high RPM. It seems to go full 36 advance, then loose a couple of degrees. Plus, my A/F ratio is at 10.4:1.
Old Sep 9, 2004 | 01:32 AM
SLEEPER 86's Avatar
Car: 86 coupe
Engine: 383
sounds like you're running rich
Old Sep 10, 2004 | 08:28 PM
Pony Killer's Avatar
Car: 1986 Z28
Engine: 355
Transmission: th400
yup i ran 11.96 @ 113.51 with my vortecs. that run.. as well as the last few runs with a crackec in half 700R that was struggling and purging fluid out the top of the case.
i've got a bunch of new goodies for it, new carb to replace the 40 year old hand me down. the 3.73 10 bolt which wasn't enough... i got a 12 bolt moser with 4.30's. and a th400 with a 4000stall converter, and a transbrake. to replace the 700R and the 3300stall converter.
with these goodies i'm hoping to get into the mid elevens at about 116
Old Sep 11, 2004 | 01:20 AM
89formula#1's Avatar
Car: 89 Formula
Engine: Carbed 5.7
Transmission: TKO-600
alright guys I went 12.83 with mine and i thought I was doing pretty good, Now steer me in the rigth direction, my timing is at 12-13 at idle and aroudn 34 up top. Now is there somthing else I can do to my motor to help it reach the lower 12's? my main goal is to go 11.9 all motor with this car and keep it a weekend cruiser.. thanks
Old Jan 7, 2011 | 01:06 PM
skinny z's Avatar
Re: best hp/et with vortec heads?
This what you get when you search. A thread from 2004.
Let's see what's happening now with stock Vortecs.
Maybe post ET, MPH, 60', weight and DA if you know it.
12.7, 105, 1.7, 3700, Sea level.
I'll qualify that with displacement too. 350.
Old Jan 7, 2011 | 01:16 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Theres 89fbirdformula who claims to make 363whp on a set of mild cleaned up vortec heads in a vortec stealth ram based combo...lean air fuel and pulling timing on the dyno, it has more in it.
old combo went 12.20's with ported TPI on stock vortec heads, so it should be an 11 second car with the new setup.
Old Jan 7, 2011 | 02:14 PM
Thridgen60's Avatar
Car: 86 Camaro
Engine: 6.0L LQ4
Transmission: 4L80E
Axle/Gears: 9 inch, 3.50
My car ran 12.5 with stock vortec heads and under .500 lift cam. And that was with the 2.73 gears in the rear and a baby 2200 stall. It dynoed at 320rwhp. It would have been damn close to 11's with the right gear and stall.
Old Jan 7, 2011 | 03:05 PM
skinny z's Avatar
Any idea as to the weight?
Old Jan 7, 2011 | 03:15 PM
Thridgen60's Avatar
Car: 86 Camaro
Engine: 6.0L LQ4
Transmission: 4L80E
mine is 3550 with me in it and 3350 with me out
Old Jan 8, 2011 | 10:27 AM
skinny z's Avatar
I'm hoping the the new chassis will be a couple of hundered pounds lighter than last years. 86 IROC-Z (old) vs 86 Coupe. That should be worth a couple of tenths.
Puts me in line with your 12.5. However I have a 3.73 gear and a 3000+ stall.
With the weak gearing and poor stall you must have been pulling hard at the top end.
Old Jan 9, 2011 | 09:04 AM
skinny z's Avatar
I would think there are a few more combinations out there.
I'd like to find something to shoot for this coming season.
Maybe there's an 11 second Vortec 350 NA with no juice lurking in the shadows...
Old Jan 9, 2011 | 09:42 AM
Awesome-X's Avatar
Car: 87 Camaro
Wow I didn't know these heads had that much potential, thats kinda crazy.
Old Jan 9, 2011 | 09:55 AM
skinny z's Avatar
I realize these are "magazine engine builds" however that kind of horsepower could get a 3300lb car down the track in the low 12's. Maybe 11.99 on a good day.
My old tank, at 3700 lbs dynoed 290/290 rwhp/rwt and runs 12.7x at 105 all day. Lighten it up by 400 lbs and 12.3's are possible. Find another 50 horsepower and 11's are close.
http://www.carcraft.com/techarticles...ine/index.html
http://www.popularhotrodding.com/eng...ock/index.html
Old Jan 10, 2011 | 08:46 PM
thirteen20z28's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
It's not a street car, but my FIL's '83 Firebird has run 11.6s with a 12.5:1 383 with lightly ported vortecs, th350 w/ 3000 (or more, can't remember exactly) stall converter, and 4.10s (9"). It's 3200 pounds with him in it. I weigh about 50 lbs more than him and have no trouble running 11.90s in it in the summer heat. 60' is usually 1.6-1.65 range. Even gets a little daylight under the left front every time
EDIT: Holy crap didn't realize this was my first post on this forum...coulda swore I've posted here before...just a lot of trolling I guess lol...anyway hello all
Old Jan 11, 2011 | 10:16 AM
skinny z's Avatar
Originally Posted by thirteen20z28
... with a 12.5:1 383 with lightly ported vortecs,...
12.5 with iron heads! Must be quite the cam. Race gas?
Old Jan 11, 2011 | 05:22 PM
Car: 1989 Camaro RS
Engine: 305 TBI
Yup race gas, 110 IIRC...Cam isn't that big, I wanna say around .530 lift, not sure on the duration. Sorry I'm vague on the details, he built it when I lived in CA and I've just driven it a few times since I moved closer...
84z96L31vortec
Aug 20, 2017 12:16 AM
Tinbender59
Mar 17, 2017 10:50 AM
z28guy134
Sep 1, 2015 11:50 PM
earlpote
Aug 28, 2015 10:42 AM
L98GTA87
Aug 11, 2015 06:55 PM
