Thirdgen streetability
Old Aug 6, 2004 | 04:56 PM
Spectre's Avatar
Car: Camaro Z281991 Engine: 5.7L/350 TPI Transmission: TH700R4 ··································· Car: Acura CL 1998
Engine: 3.0L/183
Transmission: 4 spd auto/OD
Hey, I was wondering.. I hear ppl say - oh ill get 1-3/4" hedders
to kill some torque.. and such ..
Torque is good but if it cant hook up, what the point ?
Im undergoing a vortec headed 350.. and would like to know
what is the best way to make the car more streetable..
Like.. getting a single plane instead of dual ? 1-3/4 instead of 1-5/8 ...
My car has 3:23 posi and I dont plan on changing that ..
Im also gonna get something like the hotcam, dont know what brand to pick, maybe crane ..
what would be the effect of 3:23 with 220ish duration ?
would the car be a dog off the line?
The car is to be a street car but autocross is in its objective.
what do you guys think ?
Tnx
Old Aug 6, 2004 | 05:01 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
The way your describing things would make an engine less streetable. For the street you want the lowend power and effeciency because the engine will hardly ever see the higher rpm range.
You just need to learn how to drive so you can handle the lowend power!
Old Aug 6, 2004 | 05:10 PM
Spectre's Avatar
Engine: 3.0L/183
Ya, tho 350's have good torque to get the car moving ..
just wondering how to maximise traction ..
Magazines boast about - full trottle and the tires break loose
Maybe 1-5/8 shorties and an airgap would be the thing..
but I dont know for sure ..
Old Aug 6, 2004 | 06:50 PM
EvilCartman's Avatar
Car: '82 Z28
There's people driving around with 500+ hp that have no problem with every day driving, just keep your foot out of it.
Old Aug 6, 2004 | 07:26 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
I see nothing in your plans that would indicate this setup would not be streetable. Minus the SP intake which isnt a choice component for autocross use. thats about the typical combo for a steet enthusiast.
Old Aug 6, 2004 | 08:01 PM
Spectre's Avatar
Engine: 3.0L/183
well, its not that it wouldnt be streetable, I just wanted to know
what ppl do when the want to trade some torque down low
for power upstairs ..
Old Aug 6, 2004 | 09:12 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
Put in a bigger cam.
Old Aug 7, 2004 | 12:41 AM
sellmanb's Avatar
Car: '86 Berlinetta
Wouldnt that create a less-streetable performance? lol.
If you are having problems with traction, then just get a better suspension... though you might feel EVERY bump in the road, it would still be streetable, safer of a car (because you can take corners faster in the case of an emergency), and better traction.
Old Aug 7, 2004 | 12:47 AM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
:werd: spohn owns me
Old Aug 7, 2004 | 02:17 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Stuff like bigger headers, bigger cam, etc.. don't "kill off" torque, they just move it up higher in the powerband. That might help in your case, but only when you "move it up" too high does it become unstreetable.
Old Aug 7, 2004 | 02:34 AM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
Well with in reason a cam will move the power band up in the rpm range, without killing streetability.
Old Aug 7, 2004 | 11:12 AM
Spectre's Avatar
Engine: 3.0L/183
The bigger cam and heeders seem like the answer ..
Ill check those out
Thx
Frozer!!!
Jan 19, 2024 04:55 PM
Terrell351
Jun 13, 2021 01:13 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
fastrs1891
South Central Region
Oct 20, 2015 09:24 AM
Exxon Limited
Aug 9, 2015 08:13 PM
