high compression ...stock (new ) starter is this even remotely possible??
Old Apr 23, 2001 | 12:52 AM
burnoutrpm's Avatar
how is this possible they did thid on the OLD 1969-1970 lt1's! will the starter even move this compression?? any tricks this engine im currently building for a EVERYDAY DRIVER will make a insane...yes i know insane 11.0:1 compression!! will my new staock type starter be enough??
89 firebird formula
360 10.5:1compression (350 .060 over)/fully balnced and blueprinted
comp cams xe262 cam
performer rpm intake/port matched to heads
#1407edlebrock 750
sportsman 2 heads 64cc 2.02/1.60 valves 200cc intake runner/cnc pocket ported
msd 6al/msd8.5 super condutor wires
h.e.i. proform 50,000 volt vac. advance ditributor
700r-4 with 3.08 first gear and 3.23 posi 7 5/8 rear end.
b trans shift kit(will kill shifts...suck dong!!)
shorty heddman hedders with custom 3" pipe y-pipe back(no damn cat!) with 40 series flowmaster!
griffin daul1" core rad.cutom fabrication to fit(but no cutting )
future mods: 406 roller REALLY REALLY REALLY RADICAL!!!!!
Old Apr 23, 2001 | 12:54 AM
ColinOpseth's Avatar
Car: 1987 Camaro IROC-Z
Engine: 305TPI
it won't
you will need a gear reduction starter so you will have more starting torque
Webmaster: www.IROC-Z.org
Old Apr 23, 2001 | 06:38 AM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
My 400 with 11 to 1 would turn over fine even with the battery in the trunk. Get a starter for 91-92 V8s. They used rare earth magnets and are as strong as gear reductions starters. They arn't cheep. Mine was 280.
I could not use a gear reduction because the nosecone does not fit in a standard T5 belhousing.
Old Apr 23, 2001 | 06:48 AM
JoelOl75's Avatar
Car: 88 Firebird WS6
CSI makes some pretty good gear reduction starters cheap... I think jegs has them.
Summit has their own brand of mini starter (sum-g1660) for $157.95
Old Apr 23, 2001 | 10:03 AM
spud's Avatar
Car: 82 & 91 Firebird
Engine: 400 & 355
Transmission: TH350 & 700
Axle/Gears: 4:11 & 2.72
My autozone special, I.e 82 camaro v8. Is living just fine starting my 10.8:1 408. I am running 36 deg of advance, Much more and the starter starts working real hard to start the car.
John
82 Firebird,408,Dart Iron Eagle 215's,Cam 229/239, .498/.520,TH350 Tranny, 750 Speed Demon carb, Hooker Headers(I.E. POS) Manual steering, Also a cowl for the big hole in the hood.
Shooting for low 12's.
Check out my birds new home.
Old Apr 23, 2001 | 05:45 PM
Tom 400 CFI's Avatar
Engine: LT1, L400
Transmission: ZF6, T5
Axle/Gears: 3.45, 3.31
I have the Summit brand mini gear reduction starter, and not only does it work fine, but it fits the T-5 bell housing just fine.
Old Apr 23, 2001 | 07:43 PM
D_Amlee's Avatar
Car: 89 IROC
Engine: Yes
Transmission: That, too.
I've got about 11:1 compression, and my stock starter does just fine.
Old Apr 23, 2001 | 10:31 PM
406 S10 Man's Avatar
Car: 1971 Corvette
Engine: 6.0 LS1 L92 heads sheet metal etc.
Transmission: M21 4-speed
Axle/Gears: 3.36
10.25:1 and a stock starter works fine. i hope you didn't buy the 35 dollar special from autozone, though, that will probably puke. mine was 73 bucks from napa.
88 S10
Dropped 3/4
18" Boyd Coddington Timeless 5s
Dart equipped 406
12.20 @ 115.25 mph
Old Apr 23, 2001 | 11:04 PM
zippy's Avatar
Car: 2006 Silverado 1500
Engine: 5.3L
stock one will due fine. guy from work runs circle track and was using a starter from a 97 chevy truck to start his 13.8 to 1 377.
Old Apr 23, 2001 | 11:41 PM
bottledpower's Avatar
Car: 85 IROC
Transmission: 700 r4
i have a stock starter on mine. no problems
85 IROC 350 11:1keith blacks,.555lift erson roller cam,1.5 crane roller rockers,edelbrock intake,holley 4150 750dbl pumper, nitrous oxide,full length heddman headers,true dual exhaust, 11"stall converter, 700R4, 3.73 locker
Old Apr 25, 2001 | 01:18 PM
99Hawk120's Avatar
Car: 1999 Pontiac T/A Firehawk
Engine: ***'s Engine
<font face="Verdana, Arial" size="2">Originally posted by jcb999:
I could not use a gear reduction because the nosecone does not fit in a standard T5 belhousing. </font>
Maybe YOURS didn't but I ran a GMPP Ministarter with my T5 for several months. It's on the same page in that catalog with the ZZ4 motor. Worked fine.
In case you're wondering, it replaced a stock starter that burned up.
Old Apr 25, 2001 | 01:22 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
i think there are two T5 bellhousings. The most common one requires a starter height of about 2+ inches. Most mini starters do not have this mounting height or any type of adjustment.
Old Apr 26, 2001 | 10:00 AM
99Hawk120's Avatar
i think there are two T5 bellhousings.</font>
Odd, never heard that before. Not saying you're wrong though. I had a WC T5 from a 91 RS.
Actually wait, I can think of two separate ones. The 83 (for the mechanical clutch) and the 84-92 (hydraulic clutch).
But I'm not sure what the bellhousing has to do with it. They all use the same size flywheel, and the starter mounts on the block, so I don't see how the bellhousing would screw this up????
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
sahlomonic
Sep 20, 2015 07:15 PM
corey8084
Sep 17, 2015 02:56 PM
383cam
Sep 9, 2015 06:01 AM
Formula_88AE
Sep 3, 2015 01:47 PM
