Vibration after 60mph on 91 Formula
Old Aug 15, 2004 | 08:25 PM
CarAteMyMoney's Avatar
hey all,
i just picked up a '91 formula
drives pretty nice but theres a vibration after 60mph, it feels like im running over a bunch of little bumps on the ground
just had the front wheels balanced and the problem is still there.
anyone have any suggestions as to what this might be, or what i can do to diagnose it?
Old Aug 15, 2004 | 09:04 PM
ljnowell's Avatar
Could be driveshaft? Or possibly front end alignment?
Old Aug 16, 2004 | 01:31 AM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
my moneys on driveshaft
Old Aug 16, 2004 | 05:31 AM
azvolfan's Avatar
Car: currently thirdgenless!!!
Balancing on tires?
Old Aug 16, 2004 | 10:10 AM
the driveshaft would cause that after 60?
Old Aug 16, 2004 | 01:02 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
well once it gets to a high enough rpm the minor imbalance would be vibrating more
could just be an improperly balanced tire
basically start with getting your tires checked which is dirt cheap then get alignment done( won't hurt it )
if both those fail its the driveshaft
Old Aug 16, 2004 | 02:27 PM
BIGJON's Avatar
Car: 1989 Formula 350 Firebird
Transmission: 700 R4
Re: Vibration after 60mph on 91 Formula
FYI ^
I would check you motor/tranny mounts. Check tires for any slight bumps or imperfections. Vibrations can be many things, harmonic balancer, torgue converter, etc. Start with tires, alignment, steering component checks, bushings, tranny mount, motor mounts, re-torque your mounts if needed, then check u-joints and drive shaft pinion angle.
Old Aug 18, 2004 | 12:40 PM
Is there any chance that this could be caused by something like a strut, control arm or ball joint?
Old Aug 18, 2004 | 01:06 PM
BIGJON's Avatar
Could be.....but that would be more of a clunking sound...look into that as well.
Old Aug 19, 2004 | 01:28 AM
BRobinson's Avatar
Car: 82 Camaro
Transmission: TH-350
Axle/Gears: 3.08
I had the exact problem on my 82 camaro, and i only had it about 6 months before the engine crapped out on me, so i never really got around to finding the problem. But when i went to pull the engine and tranny (2.8/TH-200), i discovered that I had NO, repeat, NO drivers side tranny mount bushing, so check on that. I hope that was what was wrong with mine. Wish me luck, cause tomorrow, the rebuilt 305 gets primed and started (hopefully) for the first time tomorrow :rockon: if that's my prob, i'll post back tomorrow night
Old Aug 20, 2004 | 06:51 PM
Congrats and best of luck!
Old Aug 20, 2004 | 07:33 PM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
Could be u-joints as well, a truck we had drove great until about 65 then had a vibration in it. Turned out the u-joints were actually loose where they connected to the rear and caused the vibration.
Old Aug 21, 2004 | 06:58 AM
littlebagz's Avatar
Car: 89 Z28
Engine: 350 with ads
Go down the road a littlel faster than when the vibration starts, say 70mph or so. Once cruising put the car in neutral and see if teh vibration goes away.
If yes then teh vibration is engine or torque converter related.
If no than it is tires or driveline related. I had a similar problem with my 89 IROC. the car had been sitting for so long, and teh tires were close to bald that there were small flatspots that caused a nasty shake....
Best of luck...
Linson
Oct 24, 2025 02:00 PM
okfoz
Oct 13, 2015 02:19 PM
bjpotter
Oct 4, 2015 07:48 PM
Linson
Oct 1, 2015 09:50 PM
