how many different compression ratios have 350's have over the years?
Old Aug 16, 2004 | 05:36 PM
92lt1's Avatar
Car: 91z
Engine: 350 vortec
Transmission: built 700r4
Axle/Gears: 373
i was just curious if someone could give me a answer to the differrent compression ratios 350's have came with over the years, mainly 80's and 90's.
Old Aug 16, 2004 | 05:53 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
ALOT.
Everything from somewhat over 11:1 in the early LT1, to 8¼:1 in the 70s an early 80s, and back up to 9¼:1 in the L98 and over 10:1 in the LT1 of the 90s.
Old Aug 16, 2004 | 06:02 PM
92lt1's Avatar
Car: 91z
Engine: 350 vortec
Axle/Gears: 373
do you know of any web sites that would give me the complete listing? ive searched and have come up dry.
Old Aug 16, 2004 | 06:25 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
I have no clue. That info, arranged that way, is pretty much useless. Not that uselessness keeps stuff off the Internet, but still.....
What is it you really are trying to find out? Maybe if you ask the right question, you can get the answer you're looking for.
Old Aug 16, 2004 | 09:35 PM
Streetiron85's Avatar
Car: '85 IROC
Engine: LB9
Transmission: 700 R4
I don't know of any sites, but a Chiltons manual covering from 69> has some data.
In the early years they used 2 different head vols and 3 different piston dome sizes. and those combos gave anywhere from 8.5/1 to 11/1, roughly.
Then they introduced the 58cc alum heads later on. But I don't think they used those with anything except for flattop pistons.
You can figure it out mathematically with the above data.
Old Aug 17, 2004 | 02:54 PM
92lt1's Avatar
Car: 91z
Engine: 350 vortec
Axle/Gears: 373
RB83L69, my cousin has around 15 or 16 350 blocks in his shed and he was curious as to what compression ratios they had and i told him to run the numbers and he said his quesiton about the compression was not answered.
Old Aug 17, 2004 | 03:05 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
If they're blocks, their compression ratio is undefined; blocks need pistons and heads and gaskets in order to have that attribute.
What is the sound of one hand clapping? This is in the same class of things.
Old Aug 17, 2004 | 05:14 PM
92lt1's Avatar
Car: 91z
Engine: 350 vortec
Axle/Gears: 373
sorry, i should have said shortblocks.
Old Aug 17, 2004 | 05:16 PM
92lt1's Avatar
Car: 91z
Engine: 350 vortec
Axle/Gears: 373
figuratively speeking with stock heads and gaskets.
Old Aug 17, 2004 | 05:20 PM
Car: '85 IROC
Engine: LB9
Shortblocks?
Still if it's a shortblock there's no way of telling what the CR is without the head.
You'll need to know the displacement of each one for starters.
Then the piston dome Vol
Then the head vol
Old Aug 17, 2004 | 05:44 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Too many varieties of "stock" heads, too many different head gaskets over the years.
And on top of that, the question remains totally meaningless, in light of the fact that those things aren't there. Short blocks don't have compression ratios; any more than only children have sibling rivalry (well, most only children don't, anyway, only the real "special" ones).
Basically, there is no answer to the question. If there is, it's wrong. That's all there is to it.
Old Aug 18, 2004 | 03:04 PM
92lt1's Avatar
Car: 91z
Engine: 350 vortec
Axle/Gears: 373
all i wanted is a complete list of gm 350 engines over the years with their specs. thanks for making me feel like a dumba@@. so does it make you feel good to run your mouth or what?
Old Aug 18, 2004 | 03:46 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
What we're trying to tell you, is that there is no such list; there are absolutely hundreds of different combinations of blocks, pistons, gaskets, and heads that have been available, most of which would end up being about 8¼:1, but many of which would have been slightly different; and even if there was such a list, it doesn't apply to what you've got, because you don't have motors, you have short blocks which by definition don't have a compression ratio. If you don't like that answer and just want to run your mouth and show that you don't understand much about motors, I'm terribly sorry, but that's just the way it is.
Old Aug 18, 2004 | 04:04 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Don't blame RB for your feelings, he's just trying to get the information across. If you'd take a look at his post count, you'd understand that he doesn't continue to type for the sake of hearing himself talk. If he did, the mods & admins would have shut him up long ago. Obviously, he's still talking, so he's got something worth listening to (and when he's wrong, which is rare, he admits it).
Now, think about what you're trying to determine: What difference does it make what compression ratio an engine had when it was delivered, if the shortblock is now sitting in a shed? If they're all 350's, then you can tell by looking at the pistons what their relative compression ratios would be, assuming each had the same head on it. But, why would you care? If you've got a shortblock sitting in a shed, it must be there for a reason, because it's not out there moving some vehicle around right now. I might be willing to take a chance on what it would do if put back into a vehicle, but only if I wasn't too concerned about how it performed if I did it. Otherwise, since it's now sitting in a shed, I'd want to disassemble it and freshen up whatever is worn, which most likely would involve overboring the cylinders, which would require replacing the pistons, anyway, at which time you would choose replacements that would give you the desired compression ratio.
Any other use of the original compression ratio data would prompt us to either; a) protect you from yourself, or b) protect others from you.
Nobody's trying to be smart with you or make you look stupid, we're here to share technical data relevant to 3rd gen F-bodies and help each other out. If a lot of time has been spent on this thread trying to figure out why you're trying to figure this out, it's because it doesn't make a lot of sense to those who understand such things why you're trying to get this kind of data.
Old Aug 18, 2004 | 10:35 PM
Car: '85 IROC
Engine: LB9
http://www.mortec.com/castnum.htm
If a list is what you want, here's one.
I'm not sure if it has what you're looking for, but it's something anyhow
Old Aug 19, 2004 | 04:08 PM
92lt1's Avatar
Car: 91z
Engine: 350 vortec
Axle/Gears: 373
yes that is close to what im looking for but with more detail like engine compression, hp, tq ect...
Old Aug 19, 2004 | 08:01 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
There is no such list, you can start on for us though. It's kinda tough though considering over 50 millions SBC have been built, the majority of which are 350's.
You will have to look in a million different sources to find all of them. Good luck!!!
Old Aug 19, 2004 | 09:40 PM
Car: '85 IROC
Engine: LB9
I have a chiltons manual that has all thet stuff in it, but it's 60s-70s.
You might be able to get a later manual that has the info you're after.
Old Aug 19, 2004 | 10:05 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
Yeah but you would have to have a chiltons manual for every year,make and model that came with a 350.
Old Aug 20, 2004 | 09:58 AM
Dustin Mustangs's Avatar
Car: I
Engine: Taunt
Transmission: Mustangs
Are you any good at math? If so, here's an idea for you, measure them. Start by measuring the bore and stroke. Here are some common stock values for those:
V8 Stock Bores and Strokes
SBC:
262 = 3.671" Bore x 3.100" Stroke
265 = 3.750" Bore x 3.000" Stroke
267 = 3.500" Bore x 3.480" Stroke
283 = 3.875" Bore x 3.000" Stroke
302 = 4.000" Bore x 3.000" Stroke
305 = 3.740" Bore x 3.480" Stroke
307 = 3.875" Bore x 3.250" Stroke
327 = 4.000" Bore x 3.250" Stroke
350 = 4.000" Bore x 3.480" Stroke
400 = 4.125" Bore x 3.750" Stroke
BBC:
366 = 3.935" Bore x 3.760" Stroke
396 = 4.094" Bore x 3.760" Stroke
402 = 4.125" Bore x 3.760" Stroke
427 = 4.250" Bore x 3.760" Stroke
454 = 4.250" Bore x 4.000" Stroke
502 = 4.468" Bore x 4.000" Stroke
Use this to get the swept volume of one of the cylinders. Then get something like this to measure your deck height volume. Add that to the volume of the head gasket you want to run and to the volume of your combustion chamber for whatever head you want to use. Make sure they're in the same units, divide the two, and blamo! That's a good ESTIMATE of your compression ratio. Like 57kid said though, if you plan on rebuilding those before you use them the compression ratio could change unless you get the exact same parts, which isn't very likely to happen.
Old Aug 20, 2004 | 03:32 PM
92lt1's Avatar
Car: 91z
Engine: 350 vortec
Axle/Gears: 373
thanks iron, me leigh and dustin, that helps
Old Aug 21, 2004 | 12:05 PM
Car: '85 IROC
Engine: LB9
https://www.thirdgen.org/newdesign/tech/techdb.shtml
And of course there's this
But it's F bodys only AFAIK
theshackle
Mar 5, 2017 06:37 PM
Reddeath210
Oct 6, 2015 08:20 AM
NinjaNife
Aug 23, 2015 11:49 AM
NWAsonoma
Aug 18, 2015 05:45 PM
BBSDesigns
Aug 11, 2015 07:39 PM
